Focus Fusebox Compatibility 2010 2.0 tdci
Old May 1, 2019 | 10:13 AM
deathrider666's Avatar
deathrider666
Damn Cars
Default Focus Fusebox Compatibility 2010 2.0 tdci
I need a new fusebox for my 2010 2.0 tdci, which numbers do I need to match to get the right one? Does it have to be keyless specific as my car is?
Old May 1, 2019 | 07:35 PM
GVK.'s Avatar
GVK.
The part number is the 7M5T-14A073-JF. I THINK the 8M5T number is software for the BCM (body control module/fuse box)
i'd be aware its not going to be a case of just whacking a fuse box in, there will need to be some degree of coding in the as-built data and coding of immobilizer/keys.
I fitted a new one to a Focus mk3 and it came with different pin layouts etc in the end had to have the Ford field engineer down to help install the damn thing..
Old May 1, 2019 | 07:48 PM
deathrider666
Damn Cars
I fitted a new one to a Focus and it came with different pin layouts etc in the end had to have the Ford field engineer down to help install the damn thing..
Thanks.
I did order one with that number, I did see ones with different 2 letters at the end but thought I'd best get one exactly the same.
Is the coding only done by ford or can it be done by someone with the right equipment?
Old May 1, 2019 | 08:47 PM
geordiegooner's Avatar
geordiegooner
Did you buy it from me on ebay? Focusr5dale
As far as I know anyone with the correct ford software can do it.
Old May 1, 2019 | 10:15 PM
deathrider666
Damn Cars
Yes I did, that's not my user name though. Hopefully I won't have to get it to Ford then as it won't start. Will soon find out.
Old Mar 5, 2025 | 08:31 PM
vikingtom's Avatar
vikingtom
i know this was posted 6 years ago but did it work? did you just get your old one cloned?,, im literally having the exact same issue now with the water damaged BCM.
Old Mar 5, 2025 | 08:35 PM
deathrider666
Damn Cars
Yes it did work except my auto lights, wipers and cruise control didn't work again, I never bothered to find out why.
Old Mar 6, 2025 | 11:26 AM
vikingtom's Avatar
vikingtom
Default BCM coding
So you just got it sent off and cloned or did they need the car to code the new one ?
QUOTE=GVK.;6794041]The part number is the 7M5T-14A073-JF. I THINK the 8M5T number is software for the BCM (body control module/fuse box)
I fitted a new one to a Focus mk3 and it came with different pin layouts etc in the end had to have the Ford field engineer down to help install the damn thing..[/QUOTE]
Old Mar 6, 2025 | 11:29 AM
deathrider666
Damn Cars
[/QUOTE]
The guy who did it was able to code it to the car.
Old Mar 6, 2025 | 12:47 PM
vikingtom's Avatar
vikingtom
cheers, I’ll get looking for a local auto electrician
studdart76
Ford Focus (All Models)
Nov 21, 2012 10:12 PM
coste1l
Ford Focus RS
Nov 29, 2009 11:24 PM
r.mota
Ford Focus RS
Feb 26, 2009 05:39 PM
AndyBrew
16
Mar 30, 2008 09:50 PM
