rs turbo zvh conversion
now then stu !!
wonderinbg if i can pick you brain matey , im going the zvh soute on my series one and im not sure on the management to go for ,ive been told the ecu from a 2 wd cossie is a simple and cheap option , but is there anything i should be looking at if i go this route , also what if any sensors will i need to run this properly on my zvh
thanks for your time mate
brian
brian
JK12
33
Apr 26, 2021 12:09 PM
