Third to 4th gear problem??
Old Apr 20, 2019 | 10:39 PM
jr20516v's Avatar
jr20516v
Default Third to 4th gear problem??
Hi All,
Just wondering if this is a common problem......1989 Sierra Cossie 2wd.....................car has sat for a long time and found that all gears are good however downshifting from 4th to 3rd does not happen..... ironically going from 3rd to 4th is fine. Any ideas? Dont want to remove the box till i find out what the hiccup may be.
Any tips most welcome
Old Apr 21, 2019 | 12:39 PM
Giorgos92's Avatar
Giorgos92
Originally Posted by jr20516v
Hi All,
Hi mate, since all the other gears shift smoothly at a guess I'd say your 3rd gear syncronizer ring is giving up the ghost
Old Apr 21, 2019 | 10:34 PM
jr20516v's Avatar
jr20516v
Cheers for your reply.
I had thought of that however if that was the case why is 3rd to 4th perfect [as they are on the same "cog' ]
Old Apr 23, 2019 | 07:59 AM
Giorgos92's Avatar
Giorgos92
I'm not sure what you mean by being on the same cog, do you mean 3rd and 4th gears share the same cog? If so I believe those are separate cogs but what they do share is their synchro hub. If I'm not mistaken 3rd gear has its own synchro ring on one side of the hub and 4th gear has its own synchro ring on the other side of the hub. So if you would have a worn 3rd gear synchro ring then 3rd gear would grind but 4th wouldn't as it has a different ring. Does it grind if you shift slower or at low rpm? What about if you're double clutching it?
Old Apr 24, 2019 | 09:38 AM
R4N SS's Avatar
R4N SS
common issue on t5 boxes - as stated above 3rd gear synchro is fooked.
if you pretent to put it into 2nd then slide it into 3rd it will go rather than from 4th to 3rd.
Old Apr 28, 2019 | 10:45 PM
jr20516v's Avatar
jr20516v
R4N SS .....Oh bugger....that doesn't sound good. Can one still buy the 3rd gear synchro?
Giorgos92....... yes, it grinds at slower rpm as you say......double clutching makes it work a treat with no problem.
Old Apr 29, 2019 | 08:12 AM
nixon_2wd's Avatar
nixon_2wd
Its not only the synchro ring, most likely the slider and gear would need changing as well as the synchro mechanism is a three part construction. Replacing only the ring will quickly deteriorate the dogs on it as the dogs on the slider and gear are worn and wont engage.
Old Apr 29, 2019 | 08:51 AM
jr20516v's Avatar
jr20516v
Cheers for that Nixon. Do you know what other cars this same T5 gearbox was in or is in at the mo ?
Old Apr 29, 2019 | 09:33 AM
nixon_2wd's Avatar
nixon_2wd
Synchro ring and slider is the same for all World Class T5 transmissions. The 3rd gear is available OEM from Tremec, but the 4th gear (input shaft) is not available anymore, so this you would have to sort. 3rd gear is 30 tooth. (It's a part of the 2,95:1 gear set often referred to as Heavy Duty T5.) I used to have a stock of new input shafts but I'm all out. Maybe Bara could help you out.
A lot of cars were fitted with T5s but there are many different ratios.
Old Apr 29, 2019 | 09:40 AM
nixon_2wd's Avatar
nixon_2wd
Be aware that on Ebay there's usually reproduced items sold and they are really bad quality. Go for OEM. AMP usually have the OEM parts you need in stock. I'm tired of using 5speeds as he never replies, so stay clear of him.
Old Apr 29, 2019 | 10:15 AM
jr20516v's Avatar
jr20516v
Wow !! you are a fountain of information... i really appreciate your help. Looks like its a gearbox out jobbie then :{
I was going to try Burton for the parts however you mention AMP............who is that exactly?
Old Apr 29, 2019 | 10:43 AM
nixon_2wd's Avatar
nixon_2wd
Here you go:
https://ampperformance.com/
Andreas
Old Apr 30, 2019 | 01:46 AM
jr20516v's Avatar
jr20516v
I will give them a hoy.....cheers again.
Old Apr 30, 2019 | 09:33 PM
jr20516v's Avatar
jr20516v
Where could i find a list of part numbers for the Cossies gearbox?
Old May 4, 2019 | 07:22 PM
COLEYST200's Avatar
COLEYST200
Just get in touch with GEARS he is your man to sort it .
everyone says use BARA but I'm not a fan of him and he will just have your pants down
Old May 4, 2019 | 10:36 PM
jr20516v's Avatar
jr20516v
Hi Coley,
As i am in OZ how does one contact GEARS......... is he the parts supplier or a fixer ?
Old May 10, 2019 | 08:17 PM
Giorgos92's Avatar
Giorgos92
I believe he is a fixer but I suppose he would be able to supply the parts you need. That's his website https://apfgears.com/
Old May 14, 2019 | 01:29 AM
jr20516v's Avatar
jr20516v
I guess him being in the US of A he will be ofay with our Cossie T5 gear boxes as i am sure the Cossie was never sold in the US .
Old May 14, 2019 | 07:55 PM
cossynut2's Avatar
cossynut2
10 Year Member
Although the Cossy was never sold in the US spare parts for the T5 are available as it was used in Mustangs and other US cars.The T5 parts are listed as World Class T5 parts.
Old May 14, 2019 | 09:07 PM
turbotrev's Avatar
turbotrev
You say that but I don’t really know of anyone that’s had any actual product failures from him but a mate of mine had a new gears built box and it’s done minimal miles and already let go, and that’s not the first one I’ve heard of, you pay for what you get a lot of the time, gears was cheap, but the rebuild was junk....
Cheers Paul
Old May 14, 2019 | 09:21 PM
cossynut2's Avatar
cossynut2
10 Year Member
Cheers Paul
I have had a fully rebuilt/upgraded T5 from Bara for 5 years with no problems at all despite it getting plenty of hard use.
Old May 17, 2019 | 09:40 AM
jr20516v's Avatar
jr20516v
Who is this Bara fella? Should he have the gearbox parts i am chasing ?
Old May 17, 2019 | 08:25 PM
GVK.'s Avatar
GVK.
http://www.baramotorsports.com/
Old May 18, 2019 | 12:03 AM
jr20516v's Avatar
jr20516v
GVK.....thank you so much. I will give him a buzz to see if he has the g/box parts.
Old May 20, 2019 | 11:13 AM
jr20516v's Avatar
jr20516v
Parts now ordered from Gears.....he was super efficient and was quick with email replies. Thx for the tip guys :}
Old May 22, 2019 | 10:26 AM
jr20516v's Avatar
jr20516v
Hi All,
How reliable are these https://apfgears.com/ people ? I have ordered the gearbox parts with them and sent a large amount of money to them as payment but heard nothing back....getting concerned now. They dont even put a name on their initial emails eg "Cheers Bob, Jim or Tony "
Old May 22, 2019 | 04:37 PM
cossynut2's Avatar
cossynut2
10 Year Member
Hi All,
Have you tried phoning them? Sometimes emails get missed?
blacky.
20
Oct 14, 2008 10:47 PM
Redkop
14
Jan 29, 2007 09:36 PM
dean sturgess
Feb 11, 2006 07:57 PM
OLDSKOOLRYAN
Dec 28, 2005 09:12 AM
Ginge !
16
Nov 15, 2004 11:59 AM
