Rs turbo fuel pipe one way valve???
Old Feb 10, 2019 | 03:09 PM
Mr//c's Avatar
Mr//c
Default Rs turbo fuel pipe one way valve???
Ok I’ve just dropped the tank out the rs for a resto.
The fuel pipe from the pump to the front has small black cylindrical valves on it one at each end.
Are these one way valves?? If so where do I get them or how do you disconnect the metal pipes from them. I have new 8mm metal pipes. But need these valves or whatever they are.
Any help appreciated. Thanks.
Old Feb 14, 2019 | 08:18 PM
Mr//c's Avatar
Mr//c
Nobody???? Surely someone knows where to get them. I tried ford but got the usual answer. We stopped stocking escort parts many years ago.
It’s a little black type filter with it seems a push fit on the metal fuel pipe and a push fit into the hard black plastic pipe. There are two on the fuel pump lines one at back and another above steering rack. But none on the return line. Anyone know where I can get two? Or what are people using nowadays ???
Old Feb 17, 2019 | 08:22 PM
muttsnutts89's Avatar
muttsnutts89
I replaced mine with reinforced fuel hose and fuel hose clips, hope that helps.
Old Feb 17, 2019 | 08:27 PM
Mr//c's Avatar
Mr//c
Hi mate thanks. I got steel fuel lines. Having them bent to shape soon. But it’s the little one way valves that are on fuel feed side there are two. One above steering rack and one at start of metal pipe near fuel pump. The steel pipe seems to slip in one side and the other slips into the hard plastic fuel pipe. I only need the valves or anyone use different ones?
Old Feb 20, 2019 | 08:44 PM
stwibs's Avatar
stwibs
They are just connectors ...think jano supplies them
dangerousbrian
Jun 22, 2014 08:04 PM
////ANTHONY
Sep 30, 2011 04:12 PM
fordsportjay
21
Mar 27, 2011 07:21 PM
cabbykarl
Mar 6, 2007 09:11 PM
220TC
Aug 20, 2004 09:36 PM
