Mk4 Escort Zetec
Old Feb 9, 2019 | 12:45 PM
FloydH's Avatar
FloydH
Default Mk4 Escort Zetec
Hi is anyone here running a Mk4 Escort Zetec with a Weber DGV or DGAS?
If so, did you manage to get an air filter under the bonnet?
How??!
Thanks
Old Feb 9, 2019 | 10:54 PM
FloydH's Avatar
FloydH
....also i just took it out, ran fine except when put foot down & it just died...fuel starvation feathered throttle & limped home
Thought the carb was fine...just checking, have I got these fuel connections round the right way? Any help much appreciated thanks
Old Feb 11, 2019 | 06:53 PM
Fjaimo10's Avatar
Fjaimo10
Dont recall the connections being out the same side but the angled connection is usualy the inlet and straight the return.
so according to your diagram the pipes should be orther way round
Old Feb 12, 2019 | 01:51 PM
FloydH's Avatar
FloydH
duh
You're right - just swapped them & took it out for a run, everything fine! Can't believe it...
Old Feb 12, 2019 | 07:41 PM
Fjaimo10's Avatar
Fjaimo10
Glad to be of assistance
cossiecrew
27
Aug 18, 2014 10:10 PM
hydejf
Jul 19, 2011 09:36 PM
mick666
Jun 16, 2010 06:49 PM
