Best clutch for 570 bhp
Old Feb 5, 2019 | 08:16 PM
timsrs's Avatar
timsrs
Default Best clutch for 570 bhp
im looking for a clutch to handle big power
around 570
car is s road going car don’t want anything snappy like an on/off switch
I’m doing a hydraulic conversion so pedal won’t be bad
any recommendations
cheers
Old Feb 6, 2019 | 07:02 PM
timsrs's Avatar
timsrs
Anyone.
Old Feb 6, 2019 | 07:08 PM
james kiely's Avatar
james kiely
martin reyland would be the man to talk to tim
Old Feb 6, 2019 | 07:15 PM
timsrs's Avatar
timsrs
Ok thanks
il give him a try
Old Feb 6, 2019 | 07:47 PM
Caddyshack's Avatar
Caddyshack
Helix high clamp from Reyland and the plate that goes with it. You will need hydraulic pedal.
Old Feb 6, 2019 | 07:57 PM
BillyEdmonds's Avatar
BillyEdmonds
I'm using a Tilton OTii in mine. 540bhp, 480lbs.
Coupled with a hydraulic conversion it drives like a standard car. Maybe even a little lighter.
Old Feb 8, 2019 | 06:39 PM
timsrs's Avatar
timsrs
This is the best single plate clutch kit for your Cosworth, we have tried them all and others don't come close. High clamp cover means that you can run upwards of 500hp without problems, we actually have several customers with closer to 600hp with this clutch reliably! The high clamp load (better than AP racing) does mean that the clutch pedal will be heavier to depress but this can be overcome by fitting our superb hydraulic clutch conversion.
  • Suitable for power levels up to 600hp
Clutch plate & cover £542*
seen this on Reyland website rates them much better than AP
Old Feb 8, 2019 | 06:50 PM
smiley's Avatar
smiley
It's Martin hadland on here mate he'll sort you out
Old Feb 8, 2019 | 09:22 PM
Caddyshack's Avatar
Caddyshack
yup, that’s the one I used.
Old Feb 9, 2019 | 08:20 AM
timsrs's Avatar
timsrs
Great how did you find it Toby on the road.
Old Feb 9, 2019 | 09:01 AM
Caddyshack's Avatar
Caddyshack
Absolutely fine. It was heavier to use but the 205 pug bulkhead was a little tricky to get the angle right on the master so it may not have been perfect and the pedal ratio was different but perfectly fine,
Old Feb 13, 2019 | 03:21 PM
timsrs's Avatar
timsrs
Hi Toby
went to buy this clutch today and they advised it wouldn’t be upto the job
my engine will be 500lb/ft torque
a lot advised on a twin plate but personally don’t fancy this
Old Feb 13, 2019 | 04:14 PM
turbotrev's Avatar
turbotrev
I think twin plate would be best esp from a reliability point of view, and even more so if your gonna give it some stick
Cheers Paul
Old Feb 13, 2019 | 04:30 PM
timsrs's Avatar
timsrs
A lot of tuners say they will be a nightmare on the road
on/off and no give.
Old Feb 13, 2019 | 05:11 PM
Caddyshack's Avatar
Caddyshack
I had no slip at 500 ftlb, will have to see when I add more
Old Feb 13, 2019 | 05:24 PM
turbotrev's Avatar
turbotrev
on/off and no give.
Possibly... but then nearly 600hp is a shit load of power to put through a single paddle plate clutch that ain’t really designed for that, just my opinion
Cheers Paul
Old Feb 13, 2019 | 05:36 PM
timsrs's Avatar
timsrs
Cheers Paul no I take all opinions on board
just spoken with Mark Shead and he used the Helix
this is what a Reyland are selling Toby and with you saying you had no issues at 500lb/ft
Old Feb 13, 2019 | 05:39 PM
Caddyshack's Avatar
Caddyshack
yeah, no,issues
Old Feb 13, 2019 | 05:55 PM
timsrs's Avatar
timsrs
Ok mate Thankyou.
Old Feb 13, 2019 | 08:19 PM
Adam-M's Avatar
Adam-M
Hi Toby
When I phoned reyland to order my hydraulic clutch they told me they have used the single plate helix on their 4x4 3dr which iirc was 600hp
Old Feb 14, 2019 | 08:51 AM
timsrs's Avatar
timsrs
To be honest I think they were covering there arse when they said it was border line
This is what I think I’ll be going for
Alcon have got to get back to me yet but Helix seems a lot more availability than any other
Old Feb 14, 2019 | 11:41 AM
turbotrev's Avatar
turbotrev
No problem dude
Cheers Paul
Old Feb 14, 2019 | 11:43 AM
turbotrev's Avatar
turbotrev
No problem dude
Cheers Paul
scoooby slayer
16
Sep 13, 2008 08:34 PM
R5FORD
14
Dec 15, 2007 06:18 AM
Moose
Aug 4, 2007 12:29 PM
cossie rich
Jul 17, 2007 11:31 PM
T28 RST
70
Dec 9, 2006 07:06 PM
