Rear beam torque settings
Old Feb 1, 2019 | 07:41 PM
qed296's Avatar
qed296
Default Rear beam torque settings
Evening all,
Having had to drop the rear beam to fit the avo's I'd like to just double check the torque setting for the rear mounting plate and main bolt up through the bush.
The 2 x 17mm bolts holding the plate to the chassis -
the main 19mm bolt up through the bush -
thanks in advance.
Old Feb 2, 2019 | 09:43 PM
qed296's Avatar
qed296
Anyone??
Old Feb 3, 2019 | 08:32 AM
Caddyshack's Avatar
Caddyshack
I just did mine “tight” and never had a problem. Yes correct torque is best but once on its wheels I don’t think those bolts take huge loading (I may be wrong)
Old Feb 3, 2019 | 09:17 AM
Albertodelgado's Avatar
Albertodelgado
Lightbulb
manual says 41 to 51Nm for the 4 small bolts, and 68,5 to 88Nm for the 2 large bolts
Old Feb 3, 2019 | 10:10 AM
qed296's Avatar
qed296
Thanks folks...I know even torqued up nuts and bolts can come loose, just want to be safe as I can.
thanks for the info
MunkeyboyRS
Aug 31, 2010 11:18 AM
Sonic Boom
11
Dec 9, 2008 10:13 PM
AGAR-COSWORTH
Fiesta RS1800/RS Turbo
16
Aug 13, 2007 11:04 AM
DaveEscos
11
Jul 2, 2004 01:53 PM
