Rear beam torque settings
Evening all,
Having had to drop the rear beam to fit the avo's I'd like to just double check the torque setting for the rear mounting plate and main bolt up through the bush.
The 2 x 17mm bolts holding the plate to the chassis -
the main 19mm bolt up through the bush -
thanks in advance.
thanks in advance.
I just did mine “tight” and never had a problem. Yes correct torque is best but once on its wheels I don’t think those bolts take huge loading (I may be wrong)
Sonic Boom
11
09-12-2008 10:13 PM
AGAR-COSWORTH
Fiesta RS1800/RS Turbo
16
13-08-2007 11:04 AM
DaveEscos
11
02-07-2004 01:53 PM
