focus st3
Old Jan 29, 2019 | 08:53 PM
Ford2.5st's Avatar
Ford2.5st
Angry focus st3
Hoping someone can help currently have a focus st3 on the odd occasion while driving it has a hesitation for couple of seconds has a flat spot but if u keep your foot down it clears and pulls fine. Also when it does this the boost gauge drops and once it’s had its moment gauge comes back to normal when I first got the car it done it but recently getting more frequent. It’s almost like a misfire like it drops a cylinder. It’s had new plugs someone scanned it and came up with mass air flow sensor which was changed but still doing it. I’m hoping someone can point me in the direction of what it can be as at the moment spending money on it I haven’t got.. many thanks in advance..
Old Jan 29, 2019 | 09:39 PM
Lee read's Avatar
Lee read
Rs turbo
Hi mate could be a number of things. As you counted out two things. Look to see if there is a vacuum leak. Could be TPS maybe coil. Also a bit more in-depth could be that the injectors are clogging up so not giving a fine mist as it should.
Old Jan 29, 2019 | 09:43 PM
Ford2.5st's Avatar
Ford2.5st
it was ran on live data injectors were checked and all came back OK it put on dyno last week and was recently remaped and seems to be doing it more frequent since remap ?
Old Jan 29, 2019 | 09:45 PM
Ford2.5st's Avatar
Ford2.5st
Maybe possbile n75 someone elsee was saying also someone mentioned boost pressure sensor ? Very hard to determine weather it's engine side of it or turbo boost side ?
Old Jan 30, 2019 | 05:59 AM
Lee read's Avatar
Lee read
Rs turbo
I'd definitely be looking at all vacuum hoses mate and then many think about TPS I'd look at other sensors. Turbo side I'd probably only look at the actuator
Old Jan 30, 2019 | 08:00 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had this like a low down miss as it was building boost or held at a low boost level. If you held it flat out it would clear. I fitted new plugs and a boost solenoid and it’s fine now. Mine had no warning lights or stored errors so was a case of trying bits lol
Old Jan 30, 2019 | 08:55 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I did reply saying try plugs first then reread it and saw you'd changed them!
I would say it's likely to be an ignition coil tbh.
pugo
Ford Mondeo Including ST
15
Dec 3, 2006 10:25 PM
Rippers
Jul 18, 2006 05:56 PM
Dave Parker
May 16, 2006 04:02 PM
46
Apr 3, 2006 11:14 PM
