Rear beam refurb
Old Jan 25, 2019 | 08:50 AM
Jules44's Avatar
Jules44
10 Year Member
Default Rear beam refurb
I am in the middle of removing my rear beam and have the following questions. I have the uprated diff mount to go on already. Car is only stage 1, just used on nice days with family etc so don’t want to add to much road noise. All bushes will be from Powerflex
1. What rear beam bush would you use yellow or black.
2. What arb bushes would you use yellow or black.
3. How much movement should I have in the trailing arm spherical bushes as I have up and down movement but no sideways movement. I know these should only be changed for the same from GGR etc
4. Rear hub nut would it be easier to undo while beam is still on the car or can they be spun off with a windy gun when the beam is on the floor, also do you have to replace these if so where from.
Old Jan 25, 2019 | 10:39 AM
Marc sierra's Avatar
Marc sierra
If it is just a road car I would use yellow bushes for the beam mounts. The arb you could probably use the black ones as well, as there are rubbers bushes in the droplinks already.
I don't think there should be any play in the spherical bearings. If you have front to back movement it will give changes in rear toe.
I think the big hub nut is best removed when still on the car. It is very tight and it's easier to put some force on while it is still on the car.
Old Jan 25, 2019 | 11:48 AM
Jules44's Avatar
Jules44
10 Year Member
Cheers for that
Old Jan 28, 2019 | 08:56 PM
Caddyshack's Avatar
Caddyshack
Don’t make the mistake and wind the passenger hub nut off the wrong way, it is a reverse thread.
Old Jan 29, 2019 | 06:46 AM
Jules44's Avatar
Jules44
10 Year Member
Thumbs up
I had a look on here before I attempted to remove it, used my sons windy gun to spin it off
Old Jan 29, 2019 | 08:06 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Power flex black mounts on the rear beam no question.
Much more positive feeling from the back with minimal extra nvh.
Old Jan 30, 2019 | 08:48 AM
The diff mounts defo make a difference on saffs.
RSLUBBY
Jul 3, 2011 10:51 AM
dingla rs
Jun 30, 2009 09:30 PM
Sonic Boom
11
Dec 9, 2008 10:13 PM
AGAR-COSWORTH
Fiesta RS1800/RS Turbo
16
Aug 13, 2007 11:04 AM
