Thoughts on this engine
Old Jan 3, 2019 | 12:38 PM
timsrs's Avatar
timsrs
Default Thoughts on this engine
looking at getting this engine and putting an EFR 76/70 turbo on
just getting thoughts instead of getting mine built
thanks
Old Jan 3, 2019 | 02:23 PM
Caddyshack's Avatar
Caddyshack
Doesn’t say if it’s been long studded and don’t know how many miles since rebuild but I would say the price is fair.
I think there is a higher spec engine for sale for not a lot more, I will check
Old Jan 3, 2019 | 02:25 PM
Caddyshack's Avatar
Caddyshack
I can see it has the escos cover on it but we’re these 200 blocks?
Old Jan 3, 2019 | 02:49 PM
timsrs's Avatar
timsrs
NMS don’t do long studding for some reason
I spoke with them a while back about building me an engine to over 500 bhp and said no long studding
Not heard of any failing at this level tbh.
They seem to use some sort of special bolts and a decent head gasket
Has anyone had a NMS engine built without long studding be interested if it going strong NOT long studding
yeah it’s originally out of a Escos.
Old Jan 3, 2019 | 02:50 PM
timsrs's Avatar
timsrs
Could you send me a link to this other engine you know about Caddy
thanks mate
Old Jan 3, 2019 | 03:43 PM
Adam-M's Avatar
Adam-M
If you have a 4x4 engine I’d just spend the money getting it rebuilt
Old Jan 3, 2019 | 03:59 PM
timsrs's Avatar
timsrs
ive got a 200 block and 2WD engine
ive also got an EFR 76/70 twin scroll with manifold
i need to check details on this engine
going to speak to guy tonight and I’ll post up what I’ve been told
Old Jan 3, 2019 | 06:25 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
The ybp as listed is from small turbo escos and has the under piston oil squirt jets as standard rather than the usual spray bar affair.
Old Jan 3, 2019 | 06:45 PM
turbotrev's Avatar
turbotrev
Bang on.
I’m having a 700hp spec engine built now by Karl and that is not studded.
There is is more than one way to skin a cat....
Cheers Paul
Old Jan 3, 2019 | 06:52 PM
turbotrev's Avatar
turbotrev
I would weigh up the costs of that engine vs what you’d need to spend on yours to make it a similar spec.
If your running that efr turbo though and are wanting nearer 600hp that eBay engine might not be specced quite enough in which case it may all need to come apart anyway....
Also a second hand engine could be a big gamble....
Cheers Paul
Old Jan 3, 2019 | 06:57 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Originally Posted by turbotrev
Bang on.
Cheers Paul
I’d be pretty worried at that power if it’s not studded properly and runs proper boost definitely rather you than me
Old Jan 3, 2019 | 07:16 PM
turbotrev's Avatar
turbotrev
Why would I be worried??
It’s built by one of the the best YB builders in the game.
Its not studded at all and it will def be running manly levels of boost
Cheers Paul
Old Jan 3, 2019 | 07:21 PM
ajamesc's Avatar
ajamesc
Cheers Paul
I guess all we can do is follow the advice of the people we trust to build these engines. There’s plenty of big power cars that have no issues using proper studs. But if your builder says he don’t need them then that’s fair enough. As you say everyone dose things differently
Old Jan 3, 2019 | 07:27 PM
turbotrev's Avatar
turbotrev
I couldn’t of said it better myself mate.
I’m not saying studs are no good, not at all.
My last engine was studded
Cheers Paul
Old Jan 4, 2019 | 09:49 AM
cossynut2's Avatar
cossynut2
10 Year Member
You have already got the base for a good engine, your call but I would probably get the work done on the existing engine. Buying a secondhand YB can be good providing it's build history is solid and been done by someone who knows what they are doing.
Old Jan 4, 2019 | 10:04 AM
Adam-M's Avatar
Adam-M
Paul, I’ve read Karl saying that before, I’m sure I read him saying he uses the standard headbolts at 500hp. What I find strange though is why mountune studded their engines at that power level back in the day and why the rs500 block and 4x4 where cast to accept longer studs? Good to see something done differently but in my opinion I’d play it safe.
Old Jan 4, 2019 | 01:00 PM
smiley's Avatar
smiley
Ask for paper work to get an exact build date to give you a rough idea how long it's been cained for these engines don't last forever as I'm sure you know I asked a tuner how long a 700 bhp engine would last he said 10k track 20k road roughly befor rebuild made me want to build from new I'd ask a price without turbo/manifold your going efr arnt you
Old Jan 4, 2019 | 02:18 PM
timsrs's Avatar
timsrs
I think I’ve found one that Caddyshack give me a heads up on
yeah I’m going EFR 76/70 twin scroll.
Old Jan 4, 2019 | 02:58 PM
smiley's Avatar
smiley
Come on spill lol
Old Jan 4, 2019 | 03:46 PM
turbotrev's Avatar
turbotrev
Whats the spec and price difference?
Cheers Paul
Old Jan 4, 2019 | 04:35 PM
timsrs's Avatar
timsrs
When I got it I will post pics
Old Jan 4, 2019 | 05:03 PM
Caddyshack's Avatar
Caddyshack
‘if Tim uses 7670 he should probably top out around 620/ 630 bhp on a good spec engine so it should last well as long as it hasn’t had a hard life before.
Old Jan 4, 2019 | 06:46 PM
smiley's Avatar
smiley
Yes mate I guess that's the gamble I thought about this when I saw yums old engine up for sale now I knew Dave and seen that well spanked 15+ yrs ago
Old Jan 4, 2019 | 06:49 PM
ajamesc's Avatar
ajamesc
that was a mistake made by me as well. If I hadn’t just paid for pistons rods and liners all them years back I’d have snapped that engine up without a second thought
andyfisher
52
Aug 12, 2011 04:51 PM
RS Classics
Aug 29, 2010 10:23 AM
gingejp
Aug 28, 2010 02:39 PM
Rob_DOHC
Jun 8, 2010 12:23 PM
Richie Russ
Ford Escort RS Cosworth
18
Jun 15, 2005 12:04 PM
