Racetech electronic Speedo on FRS MK1 gearbox
Old Jan 1, 2019 | 10:05 AM
grant_xr's Avatar
grant_xr
Default Racetech electronic Speedo on FRS MK1 gearbox
Hi
Looking to use this Speedo in my XR2 using a FRS MK1 gearbox.
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://www.burtonpower.com/racetech-speedometer-130mph-rtsc130.html&ved=2ahUKEwiO0ICpt8zfAhUrQxUIHbvmCLIQ FjABegQIBRAB&usg=AOvVaw0kGIAmBObQe_pwil4qppwN&cshi d=1546340550161
Anyone know if the original ford speedo sensor will work with this or do I need to buy a different one?
Grant
Old Jan 1, 2019 | 11:12 AM
big_wasa's Avatar
big_wasa
Yes it should,
The ford sensor is a hall afect sensor. The other type of sensor used on speedos is a Vr sensor.
The racetech instructions show it will accept either signal. I have run Etb gauges from the ford hall sensor in kitcars and it gives a very nice smooth and stable signal.
Old Jan 1, 2019 | 11:18 AM
big_wasa's Avatar
big_wasa
Old Jan 1, 2019 | 11:49 AM
grant_xr's Avatar
grant_xr
Thanks man, can order it now!
Grant
Old Jan 1, 2019 | 01:38 PM
slammedorion's Avatar
slammedorion
Your other option is something like this...
https://www.speedhut.com/Speedbox.html
Keeping the standard look...
Old Jan 1, 2019 | 01:52 PM
grant_xr's Avatar
grant_xr
Didn't realize you could buy such a thing.
I've got racetech boost and oil pressure etc gauges already so the speedo and rev counter shouldn't look too out of place along side the others.
Grant
Old Jan 1, 2019 | 02:16 PM
studabear's Avatar
studabear
We have built a controller to operate the standard Speedo from the electric sensor. Just need to do ish installing it but can't be arsed tbh
carfreak620
Mar 23, 2010 08:02 PM
