s1 gearbox
Old Apr 13, 2005 | 12:14 PM
russel7.wanadoo.co.uk@fs's Avatar
Default s1 gearbox
1800 diesel gearbox in my s1, im only doing 65mph @ 3000rpm
what gearbox can i put in to make speed higher @ 3000rpm?
ive got a s2 box but it dosnt fit, help
Old Apr 13, 2005 | 12:48 PM
rich2302's Avatar
rich2302
You may want to try something like a ghia gearbox as they are more for cruising in, diesel is all low end
Maybe a 1600i box would also be ok ?
cheers
Rich
Old Apr 14, 2005 | 07:06 AM
db's Avatar
db
If I remember well a S2 box will give 75 mph at 3200 rpm.
What's wrong with a S1 box?
Old Apr 14, 2005 | 07:10 AM
db's Avatar
db
S2 box doesn't fit? The clutch has a different size, maybe it is a matter of changing the flywheel too, than you also have the opportunity to use a 220 mm clutch.
Old Apr 14, 2005 | 09:02 AM
JesseT's Avatar
JesseT
S2 box has the wrong type left casing to accomodate the S1 style gearbox mount.
Old Apr 14, 2005 | 11:20 AM
flax's Avatar
flax
all you do is put the s2 clutch and fly wheel on then pull the ends of the s2 and s1 boxes off and swap em. thats what i`ve done. now ive got an s2 box in my s1. only other thing is you need the s2 inkage too.
Old Apr 16, 2005 | 07:56 PM
steviep's Avatar
steviep
Just change the end casing on the S2 box, deffo the way to go as you'll have an lsd then as well.
Only about an hours work with the right puller
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
