Can a cracked 200 block be repaired with a liner?????
Old Apr 13, 2005 | 11:43 AM
Disabled Account's Avatar
Disabled Account
Default Can a cracked 200 block be repaired with a liner?????
Posting for Phil2400....His Saph Cos has had a missfire/hesitation
for ages........
A few days back he did a leak down test and it showed air bubbles in the header tank, so he thought it would be the head gasket. Took head off and the gasket was fine BUT he found a crack in one of the bores
Is this block now scrap OR can it be fixed with a steel liner????
What causes a crack in the bore like that (will put pics up later)....poor casting???
Old Apr 13, 2005 | 11:57 AM
See Phillis
Old Apr 13, 2005 | 12:05 PM
richm's Avatar
richm
maybe worth speaking to Mountune Doug, I think they use liners in some applications? so may know the answer
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
It can be recovered with liners, but unless these are the Nikasel type listed in the machining section of my website, I personally would not do it above 400bhp...
Old Apr 13, 2005 | 12:21 PM
Disabled Account
RichM and MikeR - thanks for the constructive replies
Dingy - go swivel
Actually, I believe that Phil (IMA) used (or proposed using) cheapish liners,
am I correct in saying that at up to 350 BHP (greens/T34/24 PSI) that the
cheap liner repair would be OK?????
Old Apr 13, 2005 | 12:29 PM
blocks are 470 quid so whats the point LOL.....
Old Apr 13, 2005 | 12:38 PM
Disabled Account
Really??
Thats a good price, where from Dingy?
Old Apr 13, 2005 | 12:43 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
get a good old 205 block much nore reliable
Old Apr 13, 2005 | 12:48 PM
Disabled Account
Pete, I heard that too.....BUT peeps go on about how fantastic the 200 blocks on here, and that they would'nt use a 205 block for anything above Stage 1
Phil has his old 205 block still...........done about 80k......Maybe he should just use that and be done with it.........
Then again, fitting a cheap liner to the 200 block would cost about £ 100 (guessing)........So maybe that option makes more sense?
Old Apr 13, 2005 | 12:49 PM
I think Woodford have them in at that price.
Old Apr 13, 2005 | 01:11 PM
Dirty Harry
Super Moderator
I had it on good authority from a top rally X engine builder theres only a certain year 200 block to use the new ones are crap,cant beat the 205
Old Apr 13, 2005 | 03:00 PM
kjc300's Avatar
kjc300
http://cosworth.info/store/index.php?cat_id=8&catname='block'
Try £675!!!!!!!!!!!!!!
or £575 unfinished bore size (motorsport!!!)
Old Apr 13, 2005 | 03:17 PM
Mike Rainbird
Caraholic
Dingly and his "I think" comments, strike again !
Old Apr 13, 2005 | 03:18 PM
Disabled Account
OK, thanks for all the repiles and PM's.....will report back to Phill2400........I dare say that he will get his old 205 block out and use it, looks like thais would be the cheapest option .
Old Apr 13, 2005 | 03:53 PM
CraigN's Avatar
CraigN
i runa 205 block
Old Apr 13, 2005 | 03:54 PM
We have brought one at that price mike within the last 2 weeks for an escort cosworth - i think was reference to the fact they might not be that price TODAY
ImaRacing 700's Avatar
ImaRacing 700
Words from people with no clue
ALL my engines run the std liner not as strong as the nicasil (bit ott as can cause water problems as the liners are so thick they actually touch each other)...but are stronger than the original block and are tested to very high BHP....yes i will be using them in my 600plus build as hi comp needs a stronger block.
Old Apr 13, 2005 | 03:57 PM
I have lots of clue's ima.....
Candle stick, library with the maid........(not a killing, an frontal injection)
Phil's Avatar
Phil
Jeebus
I ran a 205 block no probs.
Old Apr 13, 2005 | 04:03 PM
Doug, it all depends on the crack depth, as if you liner the block but the liner isnt as deep as the crack then there is still a really bad weakness in the block that will spread further potentially.
Personally i would say the cost makes it not worth it unless you have free access to do the machining.
New 200 blocks are only half a grand or so anyway.
When people like mountune use liners, they do so on good blocks, not to repair old ones i suspect.
Old Apr 13, 2005 | 04:30 PM
markk's Avatar
markk
205 block all day long over a 200 block , seen too many 200 block failure compared to the 205's just ensure its a good one bare in mind they are older
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
rsguy
44
Sep 29, 2015 03:29 PM
20/20 vision
Sep 29, 2015 11:27 AM
