27 Spline Front Hubs 5/108 Question
Old Dec 17, 2018 | 06:54 PM
Exo-R2's Avatar
Exo-R2
Default 27 Spline Front Hubs 5/108 Question
Hi,
Currently building a MK3 Ford Focus ST ecoboost powered Rocket II kit car. Its an exoskeleton Chassis similar to an Atom. I have Mk3 ST drive shafts with 27 splines and an O/D of 29.5mm the splines are 38mm long.
Problem is I need a pair of aftermarket 5/108 pattern hubs of the older type, where the bearing is pressed into the rear and held in place with a circlip, and the hub is pressed in from the other side (similar to the image below). I can't use any that have the bearing already mounted as an assembly.
Mondeo Bearing
My question is will a Mondeo hub similar to the ones above fit the MK3 ST drive shaft splines?
Any help would be appreciated in sourcing the correct bearings/hubs I am after. Not after original ford they wanted a ludicrous £258 + vat each!
Kind Regards
Mark
https://rocket2kitcar.blogspot.com/
swannyuk
Jan 9, 2009 07:57 PM
philipeddowes
17
Feb 12, 2006 10:44 AM
pee vee
Jan 21, 2006 10:03 PM
sunny
Aug 27, 2004 01:57 PM
