18 cvh ford sierra HEATER PROBLEM
Old Dec 1, 2018 | 02:57 PM
mexico boi's Avatar
mexico boi
Default 18 cvh ford sierra HEATER PROBLEM
HI all just serviced my sierra cvh 1.8 new oil and filter and new COOLANT . ENGINE runs well and keeps good temp when driving.THE fan comes on as normal when ticking over for a bit . BUT my problem is i dont have warm air when engine is warm and all the water pipes and heater pipes are really warm. CAN anyone help/advise wat is causing this???
IS THERE A SUMMER /WINTER THERMOSTAT ??? WHAT IS THE WARMEST THERMOSTAT YOU CAN GET FOR THE CVH???
THANKS
Old Dec 1, 2018 | 03:01 PM
GVK.'s Avatar
GVK.
Heater matrix is blocked although you may have a bit of flow enough to get both pipes warm.
Old Dec 1, 2018 | 03:06 PM
mexico boi's Avatar
mexico boi
HI thanks for quick reply . IS IT A HARD BIG JOB TO SORT HEATER MATIX???
Old Dec 1, 2018 | 03:08 PM
GVK.'s Avatar
GVK.
Not done one for years but it's a dash out job I would expect.
Old Dec 1, 2018 | 03:14 PM
mexico boi's Avatar
mexico boi
Not good news but thanks gvk for your quick reply and help
Old Dec 1, 2018 | 03:20 PM
GVK.'s Avatar
GVK.
You could try flushing it through and back flushing it, might fetch some shit out.
Old Dec 1, 2018 | 06:29 PM
studabear's Avatar
studabear
Sounds like a blocked matrix like GVK said. Other possibility is heater control not working correctly. I can't remember what type of system a Sierra uses.
Old Dec 4, 2018 | 05:57 PM
steppy's Avatar
steppy
It's not hard to replace a heater rad, only the bottom half of the dash has to come out to do it
Old Dec 4, 2018 | 08:22 PM
mexico boi's Avatar
mexico boi
thanks steppy
Old Dec 4, 2018 | 08:43 PM
bigdel's Avatar
bigdel
Had similar issue in my son's old Corsa.
disconnected both end of the heater pipes from the engine, and stuck a hose down one end. Flushed loads of shit out of the matrix, was right as rain after
Old Dec 4, 2018 | 08:47 PM
mexico boi's Avatar
mexico boi
Thanks will give it a try
Old Feb 2, 2019 | 12:52 AM
Cfoy1987's Avatar
Cfoy1987
Sierra1988
Default Sierra
Did you find out the problem i have the same with mine car is running 100% but can't get heat at all
Old Feb 2, 2019 | 09:36 AM
mexico boi's Avatar
mexico boi
Hi my problem was wrong thermostat. I wanted a 92 for the winter but I couldn’t get the right one for the cvh .So I had to put the 89 bk in and the heat is not great but it all works as it should.
Robmatheson
Ford XR Range
Jun 24, 2012 08:33 PM
Minirotty
Jan 19, 2008 11:00 PM
city gent
Jan 8, 2008 09:20 AM
B19LRW
18
Jun 18, 2005 04:11 PM
