4X4 sump gasket
Oct 22, 2018 | 06:51 PM
4X4 sump gasket
Mine leaks a bit too much now!
So want to renew it, was there something about using 2wd gaskets? As they seal better, or am i thinking about something else?
Oh and anyone has the finis no's to make my trip to fords quick and simple! Cheers
Oct 22, 2018 | 07:30 PM
I use halfords gasket seal and just run a bead.
Oct 22, 2018 | 07:34 PM
Pretty sure the 4x4 doesn’t come with a gasket and just uses sealant instead
Oct 23, 2018 | 05:44 AM
As said theres no traditional gasket on the 4x4 sump, just use some red rtv or something similar
Jan 11, 2019 | 10:19 AM
looking at it, there are seals ( half moon ) at front and rear, and then as said just use a sealer.
Where does the seals?
Jan 11, 2019 | 12:20 PM
Jan 11, 2019 | 03:31 PM
Doh completely forgot about Burton, I'll pop in there at some point
matman
Jan 12, 2015 08:48 PM
Jk38
Dec 1, 2013 10:10 PM
Roosie
PassionFord Swap Shop.
Nov 28, 2010 10:32 PM
paceo
13
Aug 21, 2007 07:47 PM
