sticking a cvh sump gasket to the sump, what to use?
rtv black silicone sealent
superb sealing with no leaks and the best i have ever used
i used it on my cossie on the rocker gasket, half moons, water pump etc
nothing leaked after using that i can tell you
Silicone is ok so long as it does not go near oil!!
Silicone is Crap.
LOCTITE 5910/5900, and it will never leak again, you can even leave OFF the gasket ans it will still stick perfectly.
Silicone is Crap.
had loads of probs with my rst no matter how many new sump gaskets i put on it still leaked one of the problems is that people tighten them up to tight and bend the lip so even after you put a new sump gasket on it will still leak, the only fix really is to put a brand new one on and never over tighten it
andy
andy
..BS Motorsport..
horrible job, my first one leaked then I used some loctite stuff that was orange in colour and that worked. The gasket itself came from Halfrauds if that helps.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
