Escort Cosworth Headunit Wiring
Hi,
Putting a stereo in the RS and the previous owner has used choc blocks and crap. Wanting to ISO harness it and solder/heatshrink but does anyone have the wiring diragram for the speakers etc. so I get them right without having to test them all.
Thanks
Brendan
Thanks
Brendan
use a 9v battery to test them it takes seconds, you will hear the speaker click, look at which way the spaker moves to get the polarity the right way round
Steve
Steve
Thanks Radman, will check this weekend to see if theres one there. Is it mounted up high under dash?
Cheers Gleen, colours are different to that ,in the car harness there like yellow black, yellow green or something. Thin wires as well. But will use the Standard ISO ones to run new wires if needed.
Thanks all for the help.
mikee_rs
Oct 28, 2007 01:27 AM
