Boost leak test
Old Oct 15, 2018 | 02:23 PM
Marc sierra's Avatar
Marc sierra
Default Boost leak test
I've been trying to do a boost leak test on my Sapph 4x4 by pressurizing the inlet of the turbo, but it is immediately letting air out of the dump valve. Is this because there is no pressure on the inlet manifold yet because the throttle is closed, so the dump valve sees no pressure yet on the pilot port? Should I do the test with the throttle fully open? Or is the dump valve just not good?
Old Oct 15, 2018 | 02:38 PM
Mark Shead's Avatar
Mark Shead
You can pressure test with throttle closed as enough air will pass throttle body to hold dump valve closed.
Mark
Old Oct 15, 2018 | 03:13 PM
Marc sierra
Thanks, I will check what's wrong with the dump valve in that case.
Old Oct 15, 2018 | 03:16 PM
Caddyshack's Avatar
Caddyshack
i think I have a spare dump valve Bailey type if you need one to test it to see if the valve is faulty.
Old Oct 15, 2018 | 05:25 PM
Marc sierra
Thanks for the offer. I also have a plug to put in, so it shouldn’t be a problem to check the valve.
Old Oct 25, 2018 | 03:19 PM
BillyEdmonds's Avatar
BillyEdmonds
Charge the system using a smoke machine. It'll be very obvious where your leak is when you see the smoke coming out...
forumuser
Ford Focus Diesel
Jul 17, 2017 04:20 PM
forumuser
Ford Focus Diesel
Jul 4, 2017 09:42 AM
forumuser
Ford Focus Diesel
Jul 4, 2017 09:07 AM
xr4x4rs
21
Sep 1, 2007 11:09 AM
Mr C
Sep 7, 2005 07:27 PM
