Dash lights
Old Sep 27, 2018 | 08:06 PM
domink_goodfellow's Avatar
domink_goodfellow
Default Dash lights
I have a J plate Cosworth (later style dash) and the centre dash lights do not illuminate. So the speedo etc works fine but the clock/date, heater controls & the picture of the car (tells you the doors open etc) all don’t light up at night when the lights are on.
Also so the front fog light switch does not light up but the front & rear heated screen switch & rear fog light does.
is this a coming/easy fix?
Any help with this this would be greatly appreciated
Thanks
Old Sep 27, 2018 | 09:54 PM
qed296's Avatar
qed296
Hi,
the centre lights could simply be the plugs come off the back if the clocks been taken out or a bulb.
as for the switch I had the same Issue, just changed it for another one and it was fine.
easy to sort or at least simple to have ago at
Old Sep 28, 2018 | 06:33 PM
domink_goodfellow
Originally Posted by qed296
Hi,
Thanks I appreciate it, will look at it over the weekend & loom for another switch
RUBY123
Ford Focus RS
11
Oct 4, 2021 06:10 AM
langer
Mar 16, 2012 09:37 PM
shortie72uk
Oct 18, 2009 11:28 AM
Diamonds.
Oct 11, 2008 07:55 PM
Gez500
Ford Escort RS Cosworth
Oct 10, 2007 10:13 PM
