Dash lights
Dash lights
I have a J plate Cosworth (later style dash) and the centre dash lights do not illuminate. So the speedo etc works fine but the clock/date, heater controls & the picture of the car (tells you the doors open etc) all don’t light up at night when the lights are on.
Also so the front fog light switch does not light up but the front & rear heated screen switch & rear fog light does.
is this a coming/easy fix?
Any help with this this would be greatly appreciated
Thanks
Thanks
Hi,
the centre lights could simply be the plugs come off the back if the clocks been taken out or a bulb.
as for the switch I had the same Issue, just changed it for another one and it was fine.
easy to sort or at least simple to have ago at
Thanks I appreciate it, will look at it over the weekend & loom for another switch
langer
16-03-2012 09:37 PM
Diamonds.
11-10-2008 07:55 PM
Gez500
Ford Escort RS Cosworth
10-10-2007 10:13 PM
