focus tail lights and dash lights not working
as titled really no dash light or tail lights working or side lights. checked all fuses and there fine also changed light switch and still nothing. anyone got any ideas its a 02 plate ghia if it helps thanks
yes checked that one I've been looking on the net and apparently its quite a common problem but no one ever says the solution. i no its no fuse related as well because the other day all the lights came back on and lasted 2 days but now completely gone
Happened to a guy at work's Mondeo just last week, he had no rear sidelights and no dash lights.
Guy at the garage checked all the connections behind both fuseboxes and switches and the problem solved itself.
So although the fuses may be fine, it may be behind there one of the connections is causing the problem.
Good luck
Brian
Good luck
Brian
I have this exact problem, how did you mend it?
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
