Supra diff set up ?
Old Sep 22, 2018 | 07:52 PM
COLEYST200's Avatar
COLEYST200
Default Supra diff set up ?
Hi lads I'm thinking of selling my Supra diff with a modded beam . The diff bolts straght into the beam no fitting kit needed .
The MT diff cover that has got holes in it so it can run a oil cooler setup if you wont to . and it has got the fittings on the output shafts to bolt the cosworth inner CV joints to . It's a 3.9 with a uprated spring inside that makes the lad work a lot better .
I'm trying to find out wot this is worth as at the mo I run it on my focus with a Skyline gearbox and I'm looking at changing the diff set for next year . Wots your forts lads
Old Sep 22, 2018 | 08:56 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Who did the beam is it adjustable
Old Sep 22, 2018 | 09:01 PM
COLEYST200's Avatar
COLEYST200
Its a standard beam that I modded .
When Toby with the cosworth pug 205 gt sore it he got MK to make his the same
Old Sep 22, 2018 | 10:10 PM
smiley's Avatar
smiley
Thier hard to find now mate the 3.9 when I got mine it was 250 for diff 450 for rebuild with updated weir kit then you've got your beam on top the diffs did go up after I got mine gotta be around a bag mate
Old Sep 23, 2018 | 06:06 AM
timsrs's Avatar
timsrs
How much you want for the diff on its own
cheers
Old Sep 23, 2018 | 08:12 AM
Caddyshack's Avatar
Caddyshack
Agree with smiley, got to be worth Ł1000 or More all in.
Mark was telling me a while back thatif he was to build a new spec it would be using something like a modern corvettes mustang alloy diff. Very strong, plentiful in US and light.
Old Sep 23, 2018 | 02:22 PM
smiley's Avatar
smiley
Still the cheapest option for big power at 1k that's 2k less than a 9" ford 909
Old Sep 23, 2018 | 06:20 PM
turnover's Avatar
turnover
Thought these were the one to have ,but obviously not if your changing please tell before I buy one
Old Sep 23, 2018 | 06:24 PM
ajamesc's Avatar
ajamesc
I don’t think there is another option really other than the 9inch but that’s big money or the jag option but how easy that is to find I don’t know. The supra is tried and tested and the leg work has been done. If you have torque and grip it’s a no brainier really as there is nothing you can do with 7.5 inch diff
Old Sep 23, 2018 | 07:19 PM
c20tbo's Avatar
c20tbo
Nothing wrong with 7.5 quaife or gripper unit.............
Old Sep 23, 2018 | 07:22 PM
ajamesc's Avatar
ajamesc
The diff unit no but the cwp is made of glass. If you have torque and grip it will break if you don’t then yes it’s still an option lol
Old Sep 23, 2018 | 07:26 PM
c20tbo's Avatar
c20tbo
Plenty of Supra units failing also, you just dont get to hear about them on a ford forum.
Old Sep 23, 2018 | 07:28 PM
ajamesc's Avatar
ajamesc
yeah but cosworths aren’t ripping all the teeth off the crown wheel and pinion that’s all that counts. A few have busted the mounts but that’s engineering
Old Sep 23, 2018 | 07:34 PM
timsrs's Avatar
timsrs
This has now been sorted
MK do a beefed up cover
Old Sep 23, 2018 | 07:36 PM
ajamesc's Avatar
ajamesc
mt do one as well which dose look a little better in my opinion
Old Sep 23, 2018 | 07:56 PM
smiley's Avatar
smiley
Swap for my mk?
Old Sep 23, 2018 | 08:15 PM
R4N SS's Avatar
R4N SS
i remember a few years ago these could be bought for peanuts - im gutted i sold mine now. Should have kept it
Old Sep 23, 2018 | 08:37 PM
smiley's Avatar
smiley
I've looked for a spare recently nothing mate
Old Sep 23, 2018 | 09:15 PM
timsrs's Avatar
timsrs
MK Supply the covers to MT
Old Sep 23, 2018 | 09:17 PM
smiley's Avatar
smiley
Blanks? If he had that design when I got mine I would've had it
Old Sep 23, 2018 | 09:28 PM
smiley's Avatar
smiley
This is mk's
Old Sep 23, 2018 | 09:32 PM
Caddyshack's Avatar
Caddyshack
no, (certainly not that style) MT had his own ones done or made his own, I am not sure. Mk made one type and MT made the other. The nice blue one in the pic is an MT. I am not sure that either are still available.
Old Sep 23, 2018 | 10:37 PM
Adam-M's Avatar
Adam-M
Andrew who built your gripper?
Old Sep 24, 2018 | 08:37 AM
COLEYST200's Avatar
COLEYST200
Hi lads things have change a bit since I did this post .wot happened was I did a track day at kendrel barracks and I smashed the front diff witch is a 3.9 Ford diff the second one I've broke now . Well Sunday morning I got wind of as 3.7 Supra diff so I have bort it and it's on it's way to me . As this will let me put a 3.7 in the front witch I have 3 of them on the shelf . So it might just be the diff I might be getting rid of . No fitting kit just the diff .
As to the rear covers MK made his own covers witch looks like a tertel shell . And MT made the blue one as I've had 3. MT covers over the years I've still got 2 and I've had a MK cover all so witch I sold .there both very well made but the MT covers ticks all the boxes for me .
I don't think I've are available any more as they cost to much time and Ł to make them
Old Sep 24, 2018 | 09:40 AM
Caddyshack's Avatar
Caddyshack
There was a bloke on here re-making the castings for the R&D big front diff, whatever happened to him?
I think I will end up with an R n D when I break the crown wheel / pinion on my Quaife. I used the strengthening plate and the 2 supports which bolt to the block but I believe the CWP will be the first thing to go.
Old Sep 24, 2018 | 03:59 PM
ajamesc's Avatar
ajamesc
Mk and mt do them they look different. I have an Mk beam and an mt rear cover. Mk’s Cover has square edges
Old Sep 24, 2018 | 04:19 PM
ajamesc's Avatar
ajamesc
Me? I’m called Andrew I built my own qripper diff. Mine has a hewland engineering shot peened and super finished cwp it’s on my garage floor lol. Took it out and went supra as it’s a waste breaking it
Old Sep 24, 2018 | 05:21 PM
Caddyshack's Avatar
Caddyshack
Mark has been talking about a new cover with a "glass" window to show the crown wheel and oil level...that would be cool.
Old Sep 25, 2018 | 04:01 PM
Adam-M's Avatar
Adam-M
aww so you never actually broke the uprated cwp? Bloody gutted I would of bought it off you as I’ve just rebuilt my diff. Would of been interesting to see the tooth pattern contact between the crown wheel and pinion on yours as there’s a few steps to setting them up and if it’s not 100% then will be too much stress on the teeth.
Old Sep 25, 2018 | 05:28 PM
ajamesc's Avatar
ajamesc
I took all the teeth off a standard cwp that’s when I re built it too how it is now mate.
Old Sep 26, 2018 | 08:53 AM
lee2cossies's Avatar
lee2cossies
Any pics of how you modified the beam too take the diff? Do you do them for other people? Need too get mine done.
Old Sep 26, 2018 | 09:33 AM
Caddyshack's Avatar
Caddyshack
Here is my MK one
With diff and cover
This one has the blades anti roll bar mounts
Old Sep 26, 2018 | 09:36 AM
Caddyshack's Avatar
Caddyshack
Similar job on my cradle
Obviously this one uses the mounting kit whereas mine will not as mine has the cover on it (note the quick release option to pull the diff out the back very easily)
this is lightweight T45 so saves a big chunk of weight over a 6 degree beam with a lot more adjustment. YES it is more expensive and you really need a cage to locate it in the shell but if you compare the whole 6 degree converted etc...it is probably only twice as much...maybe a little more.
Old Sep 26, 2018 | 10:02 PM
turbotrev's Avatar
turbotrev
I haven’t seen plenty of Supra units failing???
what kind of power cars are they failing on?
Cheers Paul
Old Sep 27, 2018 | 08:27 AM
Caddyshack's Avatar
Caddyshack
I have only ever heard of a Supra diff breaking where one of the covers was not used and the diff was converted to run a cossie, it was also on a drag strip. I believe that up to 1000 bhp has been put through the Supra diff. There is a member on here who used to have a very high powered Supra and he spanked it a lot. MT has a customer with 1000 bhp drag car running his Supra diff kit.
No doubt some people can break them but they would probably break anything and there will always be the odd faliure with some units but I know for sure that less Supra diffs break at 500 bhp than standard cossie ones.
If we look at this thread Ian has busted 2 front diffs using slicks on track but the Supra diff is intact still.
Old Sep 27, 2018 | 08:36 AM
ajamesc's Avatar
ajamesc
This is the problem with the standard diff the cwp if you have torque and grip. And this wasn’t driving like a twat I was on the move floored it in second and it gripped and went bang coming off a roundabout
Old Sep 27, 2018 | 10:13 AM
Jay,'s Avatar
Jay,
Sponsor
I remember Tibbs with his 3 door @ aroumd 550 bhp used to run a mustang 8.5 rear diff and cained the mothering fucks out of it and never had a issue . There are plenty of reasonable cheap diffs to use stop being sheep lol
Old Sep 27, 2018 | 10:16 AM
ajamesc's Avatar
ajamesc
Defiantly I bet there’s a few options if your prepared to put the work in. Supra was just an easy option as it was cheap 2 years ago lol and the leg work had been done so you had a kit.
Old Sep 27, 2018 | 10:24 AM
Jay,'s Avatar
Jay,
Sponsor
In the grand scheme of things it aint that hard to mock up and the hardest bit is working out the angles of the shafts and having enough plunge and we all need some plunge lol
Old Sep 27, 2018 | 10:26 AM
ajamesc's Avatar
ajamesc
Yeah problem is the welding and fab part takes time and converting the prop and shafts. People always take the easy route less hassle lol
