HI can any one help me please just fitting a new loom with a waster spark coil set up. My new loom has a white square 6 pin plug with only 4 wires in and the original loom where it plugs in to has a 9 pin plug with 5 wires it locates behind the ECUs in the dash
any ideas on how to connect them
thanks all
If your new loom has been made specific for your car it should have come with the correct plugs ready to fit and all connections should be identified with labels.
Thanks for your reply
I bought the loom so long ago I cant remember who I bought it but thought it was for my 2 wd saph>
Would you Know if this can be modified in any way to make it work ?
Does everything else on the loom look right? Do the other connections have labels on them? It seems strange that the main plug is different. You would not have to start modifying if its the correct loom for a 2wd Saff. An auto electrician could probably sort it out if you can't remember where you got it from.
