2 wd drive cosworth wiring loom
HI can any one help me please just fitting a new loom with a waster spark coil set up. My new loom has a white square 6 pin plug with only 4 wires in and the original loom where it plugs in to has a 9 pin plug with 5 wires it locates behind the ECUs in the dash
any ideas on how to connect them
thanks all
thanks all
Thanks for your reply
I bought the loom so long ago I cant remember who I bought it but thought it was for my 2 wd saph>
Would you Know if this can be modified in any way to make it work ?
Does everything else on the loom look right? Do the other connections have labels on them? It seems strange that the main plug is different. You would not have to start modifying if its the correct loom for a 2wd Saff. An auto electrician could probably sort it out if you can't remember where you got it from.
Mark RS
06-11-2016 04:52 PM
G.Man
12-10-2005 06:33 PM
