1.8 cvh HELP
Old Sep 18, 2018 | 07:25 PM
mexico boi's Avatar
mexico boi
Default 1.8 cvh HELP
Hi I have a Sierra 1.8 cvh it broke the belt cos water pump gave up . So I fitted a new timing belt kit and new pump . It started up but it runs very lumpy . Any ideas wat needs fixing ? Wud it be my timing ? I turned the engine over by hand twice with all the spark plugs removed so it wud be easier .. Just to make sure there was no bent valves and it turned over nice and free by hand . Any help /advice wud be so good as I’m new to the site . Thanks
Old Sep 18, 2018 | 08:29 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
the timing is obvious first place to get right, if its correct, you need to run a compression test to establish which valves are bent
Old Sep 18, 2018 | 08:41 PM
martysmartie's Avatar
martysmartie
It's probably when the pump sized, valves got bent.
Martin
OrionBrian
Nov 8, 2014 12:50 PM
street
Apr 17, 2006 04:03 PM
marky_g
Mar 23, 2006 07:59 PM
liamford
Dec 11, 2005 08:54 AM
B19LRW
18
Jun 18, 2005 04:11 PM
