Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus ST225 cams
Old Aug 31, 2018 | 08:20 PM
WhySo's Avatar
WhySo
Default Focus ST225 cams
Hey all, me and a mate are changing the head gasket and doing some other maintenance while his head is off, just wondered if there is a way to check if the cams are in the correct places, cant see anything that differentiates them, thanks
Old Mar 20, 2019 | 09:12 PM
Not_Sean's Avatar
Not_Sean
Hey man,
See if you can hire the Cam locking tool, That'll sort it out for you as they are keyed at a angle on the Exhaust side. Ideally, check the Part numbers on them that should tell you which side is which.
Lambchop
May 27, 2007 10:50 PM
abdr500
Aug 7, 2006 12:18 PM
mrviper
21
Apr 2, 2005 01:58 PM
