VVT Regular Click
Old Aug 30, 2018 | 06:54 AM
Dthomas23's Avatar
Dthomas23
Default VVT Regular Click
Hi, I have recently noticed the the VVT solenoid is operating in a regular cycle. Approx every 8-10 seconds. It seems to happen at idle and normal running speeds. There is no noticeable effect on the engine. No MIL or other warnings / codes.
Has anyone had a similar issue?
Old Aug 30, 2018 | 01:13 PM
studabear's Avatar
studabear
I don't mean to insult your intelligence but could it be the Aircon clutch cycling on and off.
Old Aug 30, 2018 | 02:36 PM
STeve's Avatar
Super Moderator
fair comment as normally when they are goosed they either rattle non stop or you hear slapping in the cambelt cover
Old Aug 30, 2018 | 04:09 PM
Dthomas23's Avatar
Dthomas23
I have had a snoop around, and I’m pretty convinced it’s from the valve itself. Perhaps a little more background might be helpful to you guys. The cam belt is new, along with the tensioner, idler Pulley and water pump. The head has new valves and seats, etc. Pretty much a complete rebuild after the original cam belt stripped its teeth. If I physically hold the VVT valve, it definitely feels like it’s operating on a regular cycle. One thing that’s running through my head, is the position of the Inlet Pulley when I reassembled it? Could it be that I possibly had the position wrong. I know the cams were spot on. The things I’m thinking of now are:
Position of the VVT Pulley.
Failing camshaft Sensor.
A timing / signal issue between the Crank Andy camshaft sensors.
Or something you guys have come across. 🤗
Old Aug 30, 2018 | 07:41 PM
STeve's Avatar
Super Moderator
I would first check the VVT solonoid is working before you go diving into anything else if your sure its vvt related
Old Aug 30, 2018 | 08:31 PM
studabear's Avatar
studabear
I do remember a Volvo I mot'd years ago doing something similar to what you describe now you mention it. It failed emissions and never cae back for retest.
Old Aug 31, 2018 | 06:12 AM
Dthomas23's Avatar
Dthomas23
Thanks
I’ll take the solenoid off, see how it operates. To be honest I haven’t really spent a lot of time digging deeper into VVT issues.
​​​​So it might help me understand a little better.
Old Aug 31, 2018 | 06:16 AM
Dthomas23's Avatar
Dthomas23
That does sound intriguing. During the latest MOT, the emissions were raised, but passable.
I don’t want to start jumping to conclusions at the moment. And start thinking the Camshaft isn’t responding to the VVT calls.
I’ll do some basic checks on the solenoid first, and see what that brings me.
Thanks for the replies
Dthomas23
Aug 29, 2018 03:05 PM
doggydowg
Sep 21, 2005 11:09 PM
kevsrs
May 15, 2005 03:16 PM
Lee Reynolds
Feb 5, 2005 11:33 PM
Shows & Track Days
Mar 27, 2004 08:47 AM
