Tdc when using Kent Vernier pully
Old Aug 29, 2018 | 09:29 PM
24psi boost's Avatar
24psi boost
Default Tdc when using Kent Vernier pully
As above am wanting to change Cambelt on my series 1 rs turbo. It’s fitted with a Kent vernier pulley, but there is no pointer on the Kent pulley to align with the marks on the head?
can anyone advise how I align the pulley with the mark on the head so is at TDC?
thanks in advance
Old Aug 30, 2018 | 05:13 AM
haz87's Avatar
haz87
Use a Dial indicator and follow the proper procedure (something like http://www.burtonpower.com/tuning-gu...ng-timing.html - there are better guides but i couldnt be arsed to google for them at 6 in the morning)
Old Aug 30, 2018 | 08:18 PM
stevieturbo's Avatar
stevieturbo
C**t
TDC relates to crank position....what camwheels are fitted are irrelevant.
If you're just changing the belt and need some before/after markings, and are happy current belt is installed correctly, TippEx works wonders.
mick271*
Oct 24, 2012 08:33 PM
rst steve
Oct 29, 2006 10:08 AM
white cab
14
Mar 9, 2006 10:30 PM
Ginge !
16
May 8, 2005 07:01 PM
