Idle control valve
Old Aug 3, 2018 | 08:34 PM
jimhc's Avatar
jimhc
big jc
Default Idle control valve
I'm need some help with my idle control valve. I've just replaced it and it revs up to 2k?. Thanks Jim
Old Aug 4, 2018 | 08:19 AM
steppy's Avatar
steppy
It may be an air leak, Does it still rev to 2k with the wiring plug to the iscv disconnected?
Old Aug 4, 2018 | 08:35 AM
jimhc's Avatar
jimhc
big jc
No it sits at 850 900 when unplugged
Old Aug 4, 2018 | 09:53 AM
martysmartie's Avatar
martysmartie
I had this and I bet it's aftermarket?
The issue is the springs are not the correct type/tension.
Martin
Old Aug 4, 2018 | 12:38 PM
jimhc's Avatar
jimhc
big jc
I have 2 old 1s and they did the same thing.
Old Aug 4, 2018 | 01:12 PM
jimhc's Avatar
jimhc
big jc
I have replaced the throttle position sensor (2wd)
Old Aug 4, 2018 | 01:14 PM
martysmartie
Have you checked its output?
Martin
Old Aug 4, 2018 | 01:15 PM
jimhc's Avatar
jimhc
big jc
On the tps?
Old Aug 4, 2018 | 01:21 PM
martysmartie
Yep, it should be open circuit at idle (this is what activates the idle strategies) then with opening it should read like 4.7V, decreasing to 0.5V @ WOT.
You can just unplug it and see the difference (if any).
Martin
Old Aug 4, 2018 | 05:12 PM
jimhc's Avatar
jimhc
big jc
Yes I set that up. Can't get it perfect when shuts it's spot on When open it's off by .1
Old Aug 6, 2018 | 10:27 PM
martysmartie
That won't make any difference, as there is a tolerance.
It being open circuit is important, though.
Martin
Old Aug 7, 2018 | 07:21 AM
jimhc's Avatar
jimhc
big jc
The 1 that was on the car used to make the car judder trying to pull away. This 1 there's a tiny judder but 100s of times better. To cure that would the settings at full open should be bang on or when it's closed.
velocity
Nov 14, 2004 10:45 AM
simonc
Oct 10, 2004 11:49 AM
Ford Escort RS Cosworth
Mar 20, 2004 08:29 AM
steveRS
Jan 24, 2004 09:07 AM
