Cat vs mot
Old Jul 30, 2018 | 02:24 PM
Russ6334's Avatar
Russ6334
Default Cat vs mot
hi all my cossie is jan 1993 I suspect it should have a cat but it doesn’t though exhaust is clearly not standard
its never failed an mot for not having one but new rules says if it’s removed it’s instant failure now (word of mouth)
anyone else had issues? I don’t need an mot till may but getting worried!
Old Jul 30, 2018 | 04:34 PM
studabear's Avatar
studabear
We as testers have been able to fail a missing catalyst for a good few years now.
So I suggest taking it to you normal place And you should be fine.
K reg is on the borderline from memory. I will have a look at the flow charts.
Old Jul 30, 2018 | 04:59 PM
costina's Avatar
costina
Live long and prosper!!
Mine has not got a cat yet it passes the cat emissions due to closed loop.
Most testers are fair tbh esp with the older more interesting stuff.
Old Jul 30, 2018 | 06:10 PM
Caddyshack's Avatar
Caddyshack
‘totally agree, turn up with a very clean car, open attitude and theynlove it.
Old Jul 30, 2018 | 06:25 PM
martysmartie's Avatar
martysmartie
Having a de-cat in itself is not a failure (or at least used to be the case) rather it's that emissions requirements will not be met without it.
Martin
Old Jul 30, 2018 | 07:09 PM
studabear's Avatar
studabear
If you had a engine from a 3dr cosworth it would have to meet the emissions standard for a 3dr
Old Jul 30, 2018 | 09:52 PM
cossynut2's Avatar
cossynut2
10 Year Member
My 2wd Saff has been through 23 MOT tests since I have owned it, all done at the same place and passed every time despite many engine mods.They know the car and it always turns up nice and clean and I also think it makes a difference.
Old Jul 31, 2018 | 03:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
It doesn't need a cat, even if it is supposed to come with one originally as they were all produced before the cat legislation came into effect
Old Jul 31, 2018 | 04:23 PM
markie t's Avatar
markie t
THE REAL DEAL
10 Year Member
Any idea what year it came into effect?
Old Jul 31, 2018 | 06:14 PM
Russ6334's Avatar
Russ6334
i read it’s 1/1/93 which means mine would need a cat and removal is instant failure whether it passes emissions or not my garage tells me.
does this help? Exh emiss Q
assume thats exhaust emmissions q on vin plate
Old Aug 3, 2018 | 07:23 PM
dojj's Avatar
dojj
http://www.gtfours.co.uk/images/mot-cat.gif
Old Aug 3, 2018 | 07:24 PM
dojj's Avatar
dojj
also this
The cut off date is indeed 1st August 1992 AFAIK, but importantly, this is the manufactured date of the vehicle, and not as widely believed, the registered date.
Old Aug 3, 2018 | 08:09 PM
Russ6334's Avatar
Russ6334
also this
i spoke with my garage and they didn’t seem too concerned to be honest, they looked on a data base and had no info on my car so said they could do a non cat emmision test
so think I’m ok!
Old Aug 12, 2018 | 02:15 PM
costina's Avatar
costina
So mine is a 2wd so no cat just proper mapping on closed loop.
Not bad for a genuine 95k engine.
easily pass for a cat 😺
Old Aug 12, 2018 | 08:32 PM
iansoutham's Avatar
iansoutham
OCD Victim
My 1992 with cat fitted for reference on 106000 miles
Old Aug 13, 2018 | 01:19 PM
cossynut2's Avatar
cossynut2
10 Year Member
Costina. Very low readings, is your engine standard? The closed loop must be good!
Old Aug 13, 2018 | 05:53 PM
costina's Avatar
costina
Engine is completely standard apart from head gasket with 95k
T34.48 GrpA stage 2 turbo with cutback blades and a normal compressor housing.
55lb injectors
L8 Msd chip,coilpack,closed loop etc.
oh and 36psi peak boost.
S1
Nov 1, 2011 10:26 AM
Boost Junky
May 17, 2009 07:51 PM
baggydog
17
Jul 31, 2007 05:32 PM
Cawood
Jul 20, 2007 08:17 PM
bick888
Ford Focus RS
15
May 13, 2007 06:04 PM
