Escort CVH 1981 Starting / running issue
Old Jul 23, 2018 | 01:32 PM
DorsetFord's Avatar
DorsetFord
Default Escort CVH 1981 Starting / running issue
Hi all, 1981 Mk3 Escort 1.3 CVH fitted with the later type Lucas Distributor, Ford VV carb - Fires up ok but as soon as you let the key go back from the "starting position" to "on" she dies. If I keep her cranking she runs fine and will rev up A1 (obviously don't want to do this too often and wreck the starter / ring gear ! ).
Any ideas ? ? ?
Old Jul 23, 2018 | 02:54 PM
haz87's Avatar
haz87
Faulty ignition switch perhaps, when its turning back off the crank motion its killing the ignition circuit rather than maintaining it?
Old Jul 23, 2018 | 03:49 PM
DorsetFord's Avatar
DorsetFord
Hi, that was one of my thoughts but the probe is showing a live feed to the coil with the ignition "on" - will have to put a meter on it and check the voltage.
Fordgeezer500
12
Nov 24, 2011 07:09 PM
HYM50W
13
May 2, 2010 04:07 PM
XR4iCosworth24v
Jan 1, 2008 04:31 PM
EssexBoyRacer
Aug 27, 2005 08:12 PM
Agent_K
Aug 7, 2005 10:19 AM
