Hi spec handbrake calipers
Old Jul 19, 2018 | 05:54 PM
timsrs's Avatar
timsrs
Default Hi spec handbrake calipers
I’m on the look out for some Cosworth rear handbrake calipers
I know hi spec do them
Is there anything for sale out there.
Old Jul 19, 2018 | 06:19 PM
Mark V8's Avatar
Mark V8
Not long left on these 4x4 Cosworth ones on Ebay
https://www.ebay.co.uk/itm/Escort-si...53.m1438.l2649
Old Jul 19, 2018 | 07:27 PM
timsrs's Avatar
timsrs
Thanks but I’m after some 4 pots
to go with the 6 pot fronts
Old Jul 20, 2018 | 04:12 PM
Marc sierra's Avatar
Marc sierra
Be careful when using 4 pots on the rear. The rear can easily be overbraked since the pistons in most 4 pot calipers are too big for the rear.
Old Jul 20, 2018 | 07:00 PM
costina's Avatar
costina
Live long and prosper!!
As above a complete waste of money. Just use 320mm discs and those calipers.
Old Jul 21, 2018 | 03:00 PM
timsrs's Avatar
timsrs
Thanks
I will be balancing the rears with 6 pot fronts
Hi spec customer service is crap
Old Jul 22, 2018 | 12:38 PM
Marc sierra
How will you be balancing them using 6 pots at the front? The fact there are 6 pistons says absolutely nothing. The braking power is determined by the total surface area of the pistons and in most cases 6 pots calipers have smaller pistons than 4 pot calipers. For instance most AP 4 pots and AP 6 pots have exactly the same total surface area, so wil also give the same braking power.
If you put those AP 4 pots on the rear you will almost have the same braking power front and rear. The only reason the rear will (probably) brake less hard is that the brake disc diameter (so the leverage for the caliper) is smaller on the rear.
It can actually be dangerous messing with your brakes in such a way if you don't know what you're doing. Locking the rear wheels when you need to brake hard at high speed probably won't end well.
Old Jul 22, 2018 | 03:53 PM
timsrs's Avatar
timsrs
The pistons on the front are 32mm apposed to 24mm on the rear
Understand completely what your saying and have looked into it
But no don’t want to be facing the opposite way at 70mph
Old Jul 22, 2018 | 05:30 PM
Marc sierra
Are all pistons in the 6 pot calipers the same size? Most of the time they have 3 different sizes. And most 4 pots have 2 different sizes. So what you are saying about 32 and 24 mm doesn’t really make sense to me.
timsrs
Apr 22, 2018 08:14 PM
Char1ie
May 18, 2008 06:55 PM
kjc300
Oct 14, 2007 07:56 AM
antony215
Oct 11, 2006 07:19 AM
Niall.b
18
Apr 17, 2006 12:51 PM
