0 oil pressure on idle
Old Jul 5, 2018 | 07:31 PM
krolly's Avatar
krolly
Default 0 oil pressure on idle
as title really. on cold start pressure is around 55psi then slowly drops as the oil heats up. when driving Round stays between 35-45 psi but then on idle at a junction etc it's on 0. then drive off and it's up again? am I right in thinking a nakered pump ?
Old Jul 5, 2018 | 07:49 PM
matthart's Avatar
matthart
Always worth checking with a different pressure gauge, but probably main or big end bearings have gone, sorry
Old Jul 6, 2018 | 05:00 AM
haz87's Avatar
haz87
If it was actually at 0, you'd know about it noise alone. And by the sounds of it, you're driving about with these figures showing, so if it has been hitting 0, its going to be far more than a knackered pump and big ends to look at now
I'd be checking with a 2nd gauge/sender at this point too regardless
Old Jul 6, 2018 | 08:23 PM
krolly's Avatar
krolly
well a decent new sender fitted and oosh 15 ish psi when warm 😁 thanks guys
Old Jul 8, 2018 | 06:22 PM
haz87's Avatar
haz87
Good news
DAVE WRC
Dec 13, 2008 08:43 PM
GUZZLER
30
Apr 12, 2007 01:43 PM
stookay
Ford Escort RS Cosworth
Jul 9, 2006 07:24 PM
Nice_aRSe
May 23, 2005 06:05 PM
kris
Sep 4, 2004 09:09 AM
