Confirmation of wiring for Focus RS air temp sensor
Old Jun 19, 2018 | 05:46 PM
bigdel's Avatar
bigdel
Default Confirmation of wiring for Focus RS air temp sensor
I'm going to replace the standard Ford intake air temperature sensor in a MK1 Focus RS with a new sensor from Omex
The wiring instructions for the new sensor say
Pin 1 - Sensor out
Pin 2 - Sensor earth
I think the wires for the standard sensor are
Sensor out - white stripe/violet
Sensor earth - brown/white stripe
Anyone able to confirm this?
If I put a multi meter on the wiring will the sensor out wire (white/violet) show 12v?
Old Jun 19, 2018 | 06:05 PM
big_wasa's Avatar
big_wasa
There are two air temperature sensors on the Frs, one in the maf and the one in the elbow.
Pin outs and wire colours here,
https://passionford.com/forum/restor...frs-ecu-2.html
Edit, pins 37 + 39 both are white with a violet trace.
Old Jun 19, 2018 | 06:24 PM
bigdel's Avatar
bigdel
Not running a MAF so that's out of the equation
but if the white and violet is the signal wire then that confirms how I need to wire it thanks
luke_rs1800
Sep 17, 2014 11:11 PM
nick8saff
Jun 19, 2007 10:39 PM
