Diff breather
Old Jun 19, 2018 | 04:34 PM
The Crocodile Hunter's Avatar
Default Diff breather
I took the old nail for an mot last weekend, came away with a pass but noticed whilst it was on the ramp that there is a small oil leak from the top of the diff.
Assume it's just the breather? Are these just a small length of hose? I've not had a chance to properly look yet
Old Jun 19, 2018 | 05:00 PM
Caddyshack's Avatar
Caddyshack
Yes, may need to check the oil level but sounds all ok, why not change the diff oil anyway, pop the back off and inspect and refill.
Old Jun 19, 2018 | 09:37 PM
Probably not a bad shout, I've never changed it since I've owned the car!
Do the covers use a gasket or just sealant?
Old Jun 20, 2018 | 06:54 AM
Caddyshack's Avatar
Caddyshack
Just sealant, I used instant gasket from Halfords. I believe the diffs can wear and lose some of their locking on the lsd. Make sure you use lsd oil. (LS on the bottle) and it stinks when you take it out so lay down old rags to soak up any spills.
Old Jun 20, 2018 | 07:53 AM
Marc sierra's Avatar
Marc sierra
The actual LSD is a sealed unit. The oil for the diff is the same as the oil for a regular open diff.
The breather normally has a hose on the nipple going into the chassis rail.
Old Jun 20, 2018 | 08:17 AM
Caddyshack's Avatar
Caddyshack
How do people refresh them then? I have heard of people having refurbs, do they just replace the unit?
Bara told me that I MUST use LS oil in my diffs (admittedly I have a Quaife front and Weir Supra rear now)
Old Jun 20, 2018 | 12:20 PM
Marc sierra
I know that some transmission specialists can change the fluid on the viscous LSD and also increase the locking of them. But it is not something you can do at home. Or at least I've never heard of anyone doing it. This is all just for the standard Ford viscous LSD, any other LSD can be different of course.
Old Jun 20, 2018 | 01:39 PM
Caddyshack's Avatar
Caddyshack
Ah, yes...it was Bara who was talking to me about a refresh so he could do that.
Toby
Old Jun 21, 2018 | 11:38 AM
I thought they just use regular gear oil as the lsd part is sealed.
I've got some 75w90 at home, was just going to use that?
Old Jun 29, 2018 | 10:53 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
I just found this via google because I have the same issue on my 3dr. The drip is driving me insane. I had the oil changed and 500 ml came out and 1 litre went back in. But it vents out the top pipe.
1 it's making a mess of my garage but 2 it causes real issues where I live as oil leaks cause a defect if coppers see a drip.
When the oil was changed it was stripped open and re-sealed. All leaks are definitely via the top pipe.
Can you use a catch can or breather? Why does it happen?
Old Jun 29, 2018 | 04:04 PM
Caddyshack's Avatar
Caddyshack
I don’t know what would cause it but a breather can and allow it to return should work
Old Jun 30, 2018 | 12:49 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Can you direct me to an appropriate setup please?
Old Jun 30, 2018 | 07:29 AM
Caddyshack's Avatar
Caddyshack
I think it might need to be bespoke but I guess you could use an engine breather and modify that to suit.
Old Jun 30, 2018 | 08:08 PM
Can you not just leave the standard set up and have a longer bit of hose on the breather?
Old Aug 2, 2018 | 09:47 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
I forgot about this post as I'm not often on here now.
This is what I'm going to do. Try a much longer piece of hose and see how I go with that.
Old Aug 2, 2018 | 07:59 PM
markk's Avatar
markk
On all my diffs and box i have long pipes that run uphill to empty pots. If any leaks it has to fill the pot (not that it could) then runs back in. 👍
Old Aug 9, 2018 | 06:55 PM
Well I've been under the car to have a closer look and the pipe itself is actually in good condition.
Have to assume the seal of the rear cover is letting by?
AndyPen
Jun 30, 2018 12:44 AM
nellyscossy
Apr 2, 2012 10:47 AM
Jasesapphy
15
Aug 5, 2005 10:15 AM
