Ford Nouveau Red - Primer colour??
Old 06-08-2018, 06:12 AM
qed296
qed296's Avatar
Default Ford Nouveau Red - Primer colour??
Hi all,
Got a jacking point cover to spray.
It's a black plastic part.
Spray colour is (Hycote) Ford Nouveau Red Metallic.
I've tried a few websites but no listing for what colour primer to use.
Any ideas folks??
Old 06-08-2018, 07:31 AM
cossynut2
cossynut2's Avatar
Originally Posted by qed296
Hi all,
Any ideas folks??
Standard grey primer should be fine.
Old 07-08-2018, 08:57 AM
qed296
qed296's Avatar
Ok, I only asked as I cought an episode of gas monkey and they struggled to match a green.....they tried a different primer and it matched.
Just seems odd there's no listings for the primer.
I'll give it ago.
Old 08-08-2018, 11:41 PM
xr_craig
xr_craig's Avatar
Grey will be fine as long as it’s covered properly. If your that worried use a red primer
Old 09-08-2018, 07:13 AM
cossynut2
cossynut2's Avatar
I'll give it ago.
You may need to finish it with clear coat as its metallic.
Old 09-08-2018, 04:34 PM
qed296
qed296's Avatar
Grey primer applied.....
Old 09-08-2018, 07:51 PM
qed296
qed296's Avatar
Couple of coats of colour....looks good wet...see what it's like after a few hours in the heat.
Old 09-08-2018, 09:36 PM
cossynut2
cossynut2's Avatar
I am not sure if its just your photo but to me it looks like you have missed some small bits which are still showing the grey primer.? Make sure you cover all over the parts. You must still have some paint left in the can .Aerosol spray painting can result in a top finish,take your time and you should be pleased with the end result. Restored this old Honda motorbike, all re-painted with aerosols.
Old 09-08-2018, 09:49 PM
qed296
qed296's Avatar
Must be the light/photo....there well covered both sides.
Sprayed many a thing with cans and got really good results.
As with most things it's in the prep, primed, flatted it out..tack wiped..etc...
painted this with an old can I found in my dad's old garage years ago.
Chassis hight mock up
Old 10-08-2018, 08:43 AM
cossynut2
cossynut2's Avatar
Nice one, must have been the light when you took the photo, seems like you are spot on with your aerosol painting.
Old 10-08-2018, 09:21 AM
RichieST
RichieST's Avatar
You can get great results with aerosols, I've painted quite a few bits before. As said though it's all in the prep and take your time!
qed296
12-08-2018 06:37 AM
cutch
12
03-06-2013 05:35 AM
fordsportjay
13-04-2006 03:24 PM
fordsportjay
01-04-2006 07:32 PM
Quick Reply: Ford Nouveau Red - Primer colour??
