Is this timed up right? (New belt and tensioner)
Old Jun 18, 2018 | 01:33 PM
rog's Avatar
rog
Default Is this timed up right? (New belt and tensioner)
Fitted new cambelt and pulley to engine during build and wanted to make sure, I haven’t done one of these for about 10 years
Can’t get aux pulley to line up (even though there’s no actual mark on the housing behind it I know where it’s supposed to go, read posts saying it doesn’t matter) but I think the timing is ok with the distributor?
Cam pulleys are pointing toward each other, was a little bit of resistance to get them that way but look ok now.
Now, crank pulley! I remember this being a previous subject of confusion, is it supposed to go ON mark, middle of the mark, or AFTER the mark?? I have numerous drawings and still non the wiser.
Thanks in advance for you help ��
Old Jun 18, 2018 | 01:43 PM
martysmartie's Avatar
martysmartie
Crank pulley is correct, the rotor arm should be @ 2 o'clock @ TDC (toward the scribe), which your picture depicts.
Martin
Old Jun 18, 2018 | 02:38 PM
costina's Avatar
costina
Live long and prosper!!
All good do 2 full rotations and check again.
jaiscossie
22
Mar 10, 2015 04:55 PM
wskxd14
May 23, 2008 07:51 AM
MMartin
Jan 29, 2007 03:30 PM
