Half reading rev count
Old Jun 16, 2018 | 01:46 PM
slammedorion's Avatar
slammedorion
Default Half reading rev count
What’s the fix to make it read properly
It’s always read upto 3000rpm with the Adaptronics
Trying to get it right with the new ecu, still no luck...
There used to be a diagram on here for the fix...
Or I’ve read about a screw to adjust resistance on back of rev count?
My clocks are 1990 carb clocks
This is the next option to try...
Attached Thumbnails Half reading rev count-b2b1b830-7e3a-410f-b0f0-24791e49d18d.jpeg
Old Jun 16, 2018 | 06:23 PM
studabear's Avatar
studabear
Stuck a efi clock in it.
Old Jun 16, 2018 | 06:27 PM
studabear's Avatar
studabear
Although thinking about it I might have gone back to a mfi tacho when I went from cossie management to Megasquirt. I have a relay behind the dash like in that diagram.
Old Jun 16, 2018 | 06:52 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
Wire the rev counter to the coils using 3 diodes as per this diagram
Old Jun 17, 2018 | 08:13 AM
slammedorion
Cheers for the replies...
Fingers crossed we can get it working right
Old Jun 17, 2018 | 08:21 AM
slammedorion
That’s how it is now, only reading upto 3000 rpm
Old Jun 17, 2018 | 08:51 AM
costina's Avatar
costina
Live long and prosper!!
That's a tacho fault or you have a diode around the wrong way.
d3 is a zenner diode and is fitted in reverse as per diagram.
Old Jun 18, 2018 | 08:32 PM
slammedorion
Just had the text to say the top diagram has worked
Rev count fully working
Old Jun 18, 2018 | 08:55 PM
Caddyshack's Avatar
Caddyshack
Good news
Old Aug 14, 2018 | 09:02 PM
Carlitos's Avatar
Carlitos
I tried this a while back (about a year) but I couldn't get it to work. Had the zenner diode in reverse as per diagram and the two - pins of the coil along with their dioide. The only time the rev counter moved was when the engine cut out and the needle spiked a little. Otherwise it read 0 all the time. Tried 2 different sets of diodes, no change. Rev counter works but at half revs as expected. Any thoughts what I'm doing wrong?
stuarth
31
Mar 11, 2010 08:08 PM
lukemakepeace
Nov 12, 2007 03:11 PM
mark taylor
Nov 26, 2006 10:12 PM
mark taylor
Oct 16, 2006 12:24 AM
