Abs delete - whats needed
Alter the pipework to bypass the modulators if you are keeping the rear load valves.
If you are doing away with the rear valves then fit the master cylinder and the under bonnet brake valves from a none ABS xr3i and new brake pipes to suit.
Should be a few threads about it on here.
Jack and the Beanstalk
Aug 8, 2012 10:37 AM
gup
Dec 15, 2006 05:16 PM
gup
Alloy wheels and ICE for sale
13
Oct 21, 2006 06:21 AM
