Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
focus st 2.5 vibration under power
Old Jun 7, 2018 | 09:32 AM
endo's Avatar
endo
Default focus st 2.5 vibration under power
hi all ,
i am new to the forum , hope you can help ,first of all my wifes st has a vibration under power , it is there most of the time but the moment you lift off the pedal it stops , it doesn't feel like a miss fire its more like the engine is bolted straight to the chassis and it the engine vibration that you feel?
second this has just started , the car seems to lose boost for a second as you nail the pedal but then comes back, the boost gauge looks like it dips slightly but then comes back in , the needle just gets to half way
any help would be great
Old Jun 7, 2018 | 10:39 AM
haz87's Avatar
haz87
Inner CV joint(s)
Old Jun 7, 2018 | 10:43 AM
endo's Avatar
endo
hi haz87
Forgot to say last year for mot , outer cv boots were split .so i changed both shafts, wheel bearings on both and also had new hubs as the old shafts would not come out even in a 10 tonne press.
Gregr68
Ford Focus Diesel
Aug 3, 2017 06:59 PM
V8monster
Dec 29, 2010 01:44 PM
mr_intex
Oct 7, 2007 08:19 PM
BAZ S1
Feb 5, 2006 11:39 AM
Apr 6, 2004 09:41 PM
