Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Air Con not cold, holds pressure, compressor working
Old Jun 7, 2018 | 09:12 AM
thebigbowler's Avatar
thebigbowler
Default Air Con not cold, holds pressure, compressor working
Morning,
Decided I would check the air con pressure on my 2008 mk6 zetec s. The guage was a bit below the green zone on my guage, but not empty. I regassed the system myself until the guage was in the optimal zone. The fan and compressor kicked in immediately and sounded to be working as it should.
The air in the cabin is no colder, no matter what settings I try (re-circ etc.) I did notice that the pressure sometimes kicks back below the green zone of the guage and comes back as the compressor does it's thing.
any ideas what to try next? Answers on a postcard.
cheers.
Old Jun 7, 2018 | 10:20 AM
dojj's Avatar
dojj
Resident Wrestling Legend
is it digital?
has it got climate control?
it will be the cabin temp switch if this is the case
Old Jun 8, 2018 | 01:12 AM
JayCC's Avatar
JayCC
Usually you have to empty the tank and then refill?
I believe the recommended Ford amount is 450 (whatever the unit of measure is) but supposedly it was incorrect and supposed to be 650.
I found this in multiple places via google when I was looking at redoing mine.
Old Jun 10, 2018 | 11:44 PM
dojj's Avatar
dojj
Hi to Kwik Fit and see if a regas fixes the problem
If it doesn't then it's free
If it fits then I think it's £50
Old Jun 11, 2018 | 11:50 AM
colins2's Avatar
colins2
what did you use, i have tried the STP kit on 2 cars that was low even with the gauge in the green it was no better than before
Old Jun 11, 2018 | 01:35 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Take it somewhere that knows what there doing. They can drain the system see how much came out. Pressure test it with nitrogen to see if there’s any leaks. Vac it out then refill it with the correct amount of gas
Old Jun 12, 2018 | 12:09 PM
colins2's Avatar
colins2
As above i ended up doing this and its nice and cold now
Old Jun 14, 2018 | 04:25 PM
hairyford's Avatar
hairyford
my 2011 zetec s is going into halfords tomorrow to have the aircon looked at,£29,if they find any problems and need to service to fix another £30,mines not very cold,had to change the blower motor the other day as the fan wouldnt work on 1,2,3 settings,cheap and easy fix
ps how many posts to i lose my virginity,eek
CozzyKing
14
Sep 23, 2012 11:06 PM
bampson
Ford Focus ST
Oct 14, 2011 12:15 PM
user 7082039239
May 7, 2009 05:54 PM
Steven_RW
22
Apr 29, 2009 07:03 PM
