AC magnetic clutches
Old Jun 5, 2018 | 08:11 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default AC magnetic clutches
It's failed on the fiesta so can I simply buy a new one or does it have to be a complete pump?
If get it second hand obviously
Old Jun 5, 2018 | 08:33 PM
costina's Avatar
costina
Live long and prosper!!
I don't think they are easy to replace the clutch as they are usually rivited on.
Old Jun 5, 2018 | 08:46 PM
Just undo the bolt/nut that holds the pulley on and swap it over with a working one.
Dojj I take it you have powered to clutch up to make sure it is faulty.
Old Jun 6, 2018 | 05:33 AM
dojj's Avatar
dojj
Yup
Everything works
The system has had in it and is holding the pressure because I've been to Kwik Fit twice and got it done for free
Took a closer look the other day and the pump and stuff doesn't engage even though there is power to add from it
It sure turn, although but easily by hand but with a screwdriver providing the leverage
Not sure where to get a replacement for it though
Old Jun 6, 2018 | 10:48 AM
I bet to buy the pulley separate won't be cheap. I would be tempted to go to a scrappy and get a few.
Old Jun 6, 2018 | 02:37 PM
costina's Avatar
costina
Really?
Old Jun 7, 2018 | 06:34 AM
Fartblood's Avatar
Fartblood
Erect Member
Looking at the pulley kits it's a bolt and some circlips.
Old Jun 7, 2018 | 10:23 AM
dojj's Avatar
dojj
the pulley kits are really cheap
but on my mondeo i had to remove the pump in order to get to the circlip, what a pain in the arse that was, but on the bench it was 2 minutes, after i'd parked the car up for 8 months
on the fiesta it looks easier but it's trying to get the part in the first place
i got one off ebay for Ł15 for the complete pump so i'm not that fussed for themoment
i'll let you know over the weekend how it goes
Old Jun 7, 2018 | 10:27 AM
dojj's Avatar
dojj
Originally Posted by costina
Really?
there is a nut that holds the cover plate on, there there is another circlip inside that holds the magnet bit, there is another circlip further down that holds the electrical bits
they all come off and they can all be replaced
Old Jun 7, 2018 | 10:32 AM
Fingers crossed Dojj.
Old Jun 10, 2018 | 01:23 PM
dojj's Avatar
dojj
Turns out the wire was broken
Or
The wire was so old and exposed to the elements it was scrap for about a foot along
So I tried to find some pounds the same size but no luck so I simply inserted new wires into the old pins, a bit of heat shrink and solder and then a rubber pipe around the outside before fitting some plastic on top
The wire is so exposed and sits right next to the got side of the AC pipe that it was only a matter of time
But now it's fixed and ice cold again, thanks to a free top up from Kwik Fit the other week
But in other news, the magnet on this unit is fixed and not removable so my Ł15 replacement pump was a waste of money
Old Jun 10, 2018 | 04:41 PM
Nice find Dojj. So you can't swap the pulleys round then.
Old Jun 10, 2018 | 05:04 PM
costina's Avatar
costina
Glad you found problem and fixed it.
I thought some compressors you couldn't get the pulley off.
stick it back on eBay hopefully someone will need one.
Paul
Old Jun 10, 2018 | 11:42 PM
dojj's Avatar
dojj
In the Mondeo you can change the pulley AND magnet
But in the fiesta you can only change the pulley, the magnet bit is built into the body of the pump
Bugger
Old Jun 11, 2018 | 05:45 AM
Or well Dojj you learn something new everyday.
G420 DEL
Oct 18, 2008 09:48 PM
Hrsturbo
12
Mar 8, 2008 11:43 AM
pete mcrash
Feb 1, 2008 04:12 PM
Red16
38
Dec 13, 2005 02:22 AM
XRTypeRS
Jun 28, 2004 01:49 PM
