RS2000 wiring
Old May 25, 2018 | 05:58 PM
Picky7's Avatar
Picky7
Default RS2000 wiring
Hi im new to the site and need to know if anyone has a wiring diagram for the fuel pump on a 92 mk5 RS2000 please.TIA
Old May 26, 2018 | 11:14 AM
martysmartie's Avatar
martysmartie
Don't have a wiring diagram, but they pretty much all work in the same method.
That being a switched supply (via a relay) which the ECU drives and an earth.
Martin
Old May 26, 2018 | 11:31 AM
Picky7's Avatar
Picky7
Cheers 4 the reply,the problem ive got is pump isnt working,i can hear the relay prime on ignition but ive only got a perm positive at pump plug,ive been told i should have a perm and a switch live pressumably from the relay? Just need 2 find a diagram😭😭
Old May 26, 2018 | 11:38 AM
Picky7's Avatar
Picky7
Martin
Cheers 4 the reply,the problem i have is no pump,ive been told there should be a perm live and a switch live,ive got a perm live at the pump plug but no switch live,i hear the relay prime but dont get any power at the plug when it does.Could realy do with finding a wiring diagram 2 see what wires do what😭😭
Old May 26, 2018 | 03:05 PM
Caddyshack's Avatar
Caddyshack
Are they perm live and switched earth? Where Ecu provides the earth.
Old May 26, 2018 | 03:18 PM
Picky7's Avatar
Picky7
I dont know mate thats why i need a wiring diagram
Old May 26, 2018 | 06:04 PM
Mark V8's Avatar
Mark V8
I know the Mk6 RS2000 works like that.
Old May 26, 2018 | 07:57 PM
GVK.'s Avatar
GVK.
Normally the fuse box has an internal fault on those and loses the supply to the relay.
Old May 26, 2018 | 08:37 PM
Mark V8's Avatar
Mark V8
Had to fire up and old copy of windows XP and dig out the TIS disc
Screen shots below, this is for 94 onwards 2WD
Old May 26, 2018 | 08:48 PM
Picky7's Avatar
Picky7
Thank you Mark v8 Found the problem,turns out the fuel pump is goosed
messcortmk6
Sep 25, 2007 05:55 AM
Mk5_XR3i_130
Dec 31, 2006 09:01 AM
Punter
Ford Classics & Vintage
Feb 8, 2005 02:18 PM
MKII Garry
Nov 2, 2004 07:40 PM
soulweavers
15
Jul 12, 2004 03:19 PM
