Calling Zetec turbo boys
Hello folks,
Just about finished my conversion , I'm running Omex 600. It's firing but won't run unless you give a squirt of brake cleaner. The guy at Omex said the standard injectors won't be sufficient and I get that but I would have thought for starting they would be OK. I'm also running a standard new rst Bosch pump. Am I missing somthing ? Any help would appreciated
Thanks for the quick reply folks,
The plugs smell of fuel and the exhaust manifold is getting warm on all four ports so I'm guessing I'm nearly there. As for the Map Karlos I called Omex and told them what was what and he emailed me a map which a mate then loaded on to the ecu. If you think the pump is up to the job I will give Omex another ring in the morning.
Hello folks, just a small update. I've been dicking around over the last couple of days. The car runs with a bit brake/clutch cleaner because theirs ( I believe) low fuel pressure . The actual rail pressure is 2.7 bar. Looking through an Escort Haynes manual its sayning the main line pressure on the ke jetronic is 5.5 to 6.0 bar . So I rekon I'm well down. Barring a kink or somthing in the the fuel line I'm going to get hold of a new pump, I'll let you know
BARS789
347
May 27, 2011 05:02 PM
my-first-rst
Jan 17, 2010 07:16 PM
