Fusion Rear End Jumping To The Right
My Mrs 2002 1.4 petrol Fusion developed a problem a few months back with the rear end bouncing out to the right even when hitting small bumps but especially dangerous hitting bumps on left hand corners. Both shocks were replaced in the last 2 years and can't see any leaking, I also can't see anything wrong with the rear springs.
Is there a known cause of this?
I've even changed the wheels to see if there was a difference but no.
Thanks for the reply.
Yeah bloody scary, I haven't had chance to have a proper look just a glance, it did go through an MOT like it though, I was hoping they would have picked up on something.
Needs sorting or your pf username will be very apt. You would hope an mot would pick up on springs, shocks, bushes etc.
Don’t rule out something moving on the front, even an angina mount, it can all have an effect.
Could even be a dodgy tyre carcass
I've done the rear axle bush on the driver's side but now I've gone to the passenger side I've undone the nut from the bolt going through the bush but can't remove the bolt as the petrol tank is in the way. I've tried moving the bush to get the bolt to point downward to allow me the room but no luck.
Any ideas?
Any ideas?
Yep, I saw it when I went back and had a look.
3 bolts, drop the bracket down and loads easier. Wish I'd noticed on the other side.
Last edited by deathrider666; May 20, 2018 at 08:46 PM. Reason: Wrong word inserted
Pabby
Feb 2, 2013 04:53 PM
nemo.shark
May 8, 2010 06:40 AM
col93saphcos
Mar 11, 2010 07:50 PM
Charlie Chalk
Nov 17, 2004 06:04 PM
MadMac
Sep 12, 2004 10:01 PM
