Fusion Rear End Jumping To The Right
Damn Cars
My Mrs 2002 1.4 petrol Fusion developed a problem a few months back with the rear end bouncing out to the right even when hitting small bumps but especially dangerous hitting bumps on left hand corners. Both shocks were replaced in the last 2 years and can't see any leaking, I also can't see anything wrong with the rear springs.
Is there a known cause of this?
I've even changed the wheels to see if there was a difference but no.
I would get a 4 wheel alignment checked, preferably by someone who can look at the shocks, bushes and springs for movement and wear...probably an MOT equipped place.
Sounds scary!
Sounds scary!
Damn Cars
Thanks for the reply.
Yeah bloody scary, I haven't had chance to have a proper look just a glance, it did go through an MOT like it though, I was hoping they would have picked up on something.
Needs sorting or your pf username will be very apt. You would hope an mot would pick up on springs, shocks, bushes etc.
Don’t rule out something moving on the front, even an angina mount, it can all have an effect.
Could even be a dodgy tyre carcass
Fartblood (03-06-2018)
It is a shame you are so far away as you could have popped it on my ramps and we could have taken a look. I am near Guildford in surrey if you travel this way at all?
Damn Cars
Damn Cars
I've done the rear axle bush on the driver's side but now I've gone to the passenger side I've undone the nut from the bolt going through the bush but can't remove the bolt as the petrol tank is in the way. I've tried moving the bush to get the bolt to point downward to allow me the room but no luck.
Any ideas?
Any ideas?
Damn Cars
Yep, I saw it when I went back and had a look.
3 bolts, drop the bracket down and loads easier. Wish I'd noticed on the other side.
Pabby
02-02-2013 04:53 PM
nemo.shark
08-05-2010 06:40 AM
col93saphcos
11-03-2010 07:50 PM
Charlie Chalk
17-11-2004 06:04 PM
MadMac
12-09-2004 10:01 PM
