General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi I'm new to this but can anyone help?
I need to change front wheel hub and bearing. I have dismantled everything but can't get to drive shsft out of the hub, it's stuck solid.
Anyone had this problem before?
Thanks
Iv never done this job on a focus but I would of just fourt it was a case of removing the Big nut a shot of DW40 on the splines and a nice solid hit with a brass mallet to push the CV joint backwards
Loosen it all off, leave the drive shaft nut on about half a dozen turns, and give it a couple of good firm blows with a copper hammer, should come out.
Done up to a ridiculous torque so will be f-tight
Make sure you put a new nut on when you put it back together
If it's a mk1 Focus or any other Ford with 4 stud wheels then use a cheap hub puller, about Ł10
If it's a mk2 or any other with 5 studs then the hub pullers are a bit more expensive
Attach to the hub with a couple of wheel bolts and wind down the screw, easy, best though to use a couple of scrap wheel bolts
