What head gasket to use for Zetec turbo?
i have an ST170 bottom end with a blacktop head. I was quoted £144 for a 1.8mm genuine RS focus gasket from ford, or Pumaspeed do a 4 layer MLS gasket for around £70. Obviously it would be nice to spend less, but if there’s one that will out-last others, i would spend the extra, but also need the right CR.
Any advise before fore I buy either of these?
I would go with the Ford gasket. make sure the block is decked and the head is skimmed so you have perfect mating surfaces.
My first run using the st170/blacktop I never had the block decked and I blew the Cometic MLS gasket after a particularly fast run, the engine always ran hotter too.
I then redid it all with the Ford 1.8mm gasket, decked block and head refaced and its been bang on since.
That answers that question, thanks very much
whilst the engine is stripped as I need to get the block decked, should I replace anything else apart from the rod bolts if the bores look good?
TomPengelly
Jan 19, 2015 03:55 PM
dandannydandan
Aug 1, 2009 08:54 PM
dandannydandan
Aug 1, 2009 10:29 AM
Roosie
Jan 13, 2006 03:31 PM
